Liked 19 Times in 7 Posts
I have a H/CM camaro that I run in the local S/SS series. My problem is this. With minimum weather change the car is breaking out by at least .12 on the breaks. If I hold it it through the lights will break out by .16 or more. For instance in 3 time runs, it ran exactly the same, within .006. Ist round maybe 25 minutes later...it goes .11 faster on the breaks hard. 350/330hp Vortec combo in a 68 Camaro. The 60ft times are always the same 1.51-1.53. It seems to be gaining before the 1/8 mile looking at the time slips. Where should I start looking? Any help would be greatly appriciated...i hate loosing in the first round with a .020 light.
Tony Valerio 1968 Camaro 1700 IHRA H/CM 1701 NHRA SS/?A |
Liked 364 Times in 138 Posts
If you're talkin' Saturday, the tailwind in first round could have pushed you under.Then again, if you're gettin' tired of losing that way, I have a list of ways to head home in a different fashion!! Glad to share those with you anytime.
No worries TV, you'll get a handle on it.
Dave Turner SS/GT #1153 |
Liked 13 Times in 7 Posts
Quit (trying I meant) dialing so hard and freight training it. Just dump at the 1000 and 1254 marks and you'll be all set. Or dial softer and fender them or back into them.
N/A |
When I had issues like that between the 60' and 330' timers, it was the torque converter I was using with my 3-speed.
Never had a swing like that though. Mine was more like .03-.05 What is your converter, gear, trans combination, and your launch/shift RPM's? |
Stick car or Automatic? I had issues just like that in my 3 speed but my problem was the darn electric shifter, the RPM switch was bad and one round to the next it would shift like 5-600 Rpm Different.
Eric Bowling |
Liked 5 Times in 3 Posts
Put a trans temp guage on the car! running 25 mins after a time run I bet the trans was hotter then it had been all day...
#7 | |
Tony Valerio 1968 Camaro 1700 IHRA H/CM 1701 NHRA SS/?A Last edited by CrateCamaro; 09-04-2008 at 07:20 PM. |
I say 25 minutes...it was probably an hour for real. Whats a good temp to be at with a 350 turbo?
#9 | |
Tony Valerio 1968 Camaro 1700 IHRA H/CM 1701 NHRA SS/?A Last edited by CrateCamaro; 09-15-2008 at 07:36 PM. |
#10 | |
According to the TCI information, you don't have enough gear, and are not spinning enough RPM's to use that Group 4 converter.
If you aren't running class heads up, and want bracket style consistency, an 8" Opel style converter would be the choice, I think. Quote:
Jeesh, that didn't work very well...... http://www.tciauto.com/Products/Comp...p_conv_7in.asp Last edited by Dave Goob Cook; 09-05-2008 at 12:23 PM. Reason: Fubar |
