Old 09-17-2008, 05:30 PM   #1
Gear Jammer '94
Guest
Posts: n/a
Default steel or cast crank for Stock Eliminator?
Putting together a GT/C '94 Camaro with a Jerico for IHRA Stock Eliminator ('71 LT1 350/330). Would you recommend running a cast crank? Solid lift cam should pull to 7,000 rpm. If not, should I just by-pass trying to find a GM steel piece and go aftermarket? If so anyone recommend a particular brand that they have had luck with or one that I should stay away from? I've heard the cast is lighter than the forged but was wondering if it would live behind a 4-speed.
Thanks for the help!
Old 09-17-2008, 06:04 PM   #2
Chris1529
Liked 70 Times in 29 Posts
Default Re: steel or cast crank for Stock Eliminator?
You have to use the crankshaft that came from the factory in that engine.
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 09-17-2008, 07:03 PM   #3
David Lee
Liked 346 Times in 126 Posts
I would go cast, I know of many of SS cars that use cast and thier cranks last under must harsher conditions.
Old 09-17-2008, 07:16 PM   #4
Liked 1,912 Times in 429 Posts
If IHRA Stock rules are like NHRA Stock rules, you must use a factory forging or casting. You can use a GM forged crank, that's what I'd run for the sake of longevity. A cast crank MIGHT be a little faster, but it'll be measured in hundredths, if at all.
Old 09-17-2008, 08:31 PM   #5
james schaechter
Smile Re: steel or cast crank for Stock Eliminator?
I have been tempted, but the thought of taking the crank out in 3 easy pieces keeps me from going cast. Must be factory crank. Remember, your crankbone is connected to the transmission bone etc. with a stick!
James Schaechter 3163 STK
Old 09-17-2008, 09:14 PM   #6
Bub Whitaker
Cast crankshaft, properly prepped is fine for that application... won't last any less than forged GM crank prepped the same. GM forged cranks aren't made of premo material and I have probably seen more cracked steel ones than cast...Make sure you select a core that has good cheeks on the top of the rod throws and good oil hole placement on the rod & main journals. Important to find a crank grinder that knows what he is doing as far a journal radius and to further enhance the life of your bearings, it helps emencely to have the crank surface hardened \ nitride or equivalent...
Bub Whitaker is offline   Reply With Quote
Old 09-17-2008, 09:32 PM   #7
Joe DeMarzo
Liked 121 Times in 11 Posts
Bub, that is way you are the man,
Joe DeMarzo 1317 STK
Old 09-18-2008, 09:37 PM   #8
Bub Whitaker
So Joe.. thanks for the vote of confidence.. just another post to get me to senior status like you are... unless Admin will just grant it...
Old 02-22-2009, 06:56 PM   #9
treessavoy
Liked 4 Times in 4 Posts
With an automatic I would say it's a toss-up on the crank.
I would be leery of a cast crank in a high-horsepower stick car.
Old 02-22-2009, 07:15 PM   #10
Bub Whitaker
Enlighten me...since you opened this thread again, others would would like to hear your experience
Bub Whitaker
