Old 09-24-2008, 01:02 PM   #1
ss wannabee
Liked 7 Times in 7 Posts
Default SBC cylinder wall thicknesses?
Anybody got an idea what the older SB Chevy blocks (cast prior to 1962) measure up in a sonic test? How does that compare to the best 350 blocks? I think I read that Chevrolet changed or tried to make lighter at least 3 or 4 times over the years.....I think the mid/late '80's were the start of the worst when they started to crack in the valley area....I know a bunch of the early stuff (especially the 265) could be bored out to even .125" SAFELY....but you sure couldn't do that with today's production stuff! I once lifted a 265 bare block and it felt a ton heavier that the 1964-283 we are running....Not talking about GM Performance stuff here....which I'm sure have the 'beef' in all the right places!
ss wannabee is offline   Reply With Quote
Old 09-24-2008, 01:21 PM   #2
Mike Pearson
Mike Pearson's Avatar
Liked 1,955 Times in 590 Posts
Default Re: SBC cylinder wall thicknesses?
I have been told that you need at least .175 wall thickness on the thrust side. The bowtie block is the way to go. The old 4 bolt 350 blocks with the long ID pad are usually OK at .060 over.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 09-24-2008, 01:39 PM   #3
SSDiv6
Do the smart thing and map each cylinder by sonic checking.
Old 09-24-2008, 01:55 PM   #4
55 Chevy
55 Chevy's Avatar
Liked 20 Times in 15 Posts
Yes the old '56 265 991 castings can safely be bored .125 while the 57 265 548 castings can go even more.About .165 I think. 1958-62 283's also had thicker cylinder walls & can be bored to 4.000" when new. In 1963 until 1967 GM changed the 283 & the cylinder walls were thinner. I believe about.060 was about the most you could go with those ones. Those ones would definitely be lighter than the 265 blocks.
55 Chevy is offline   Reply With Quote
Old 09-24-2008, 04:25 PM   #5
STK4340
How about original Chevy II blocks, both 283 and 327? How do these fair in strength and cylinder wall thickness? I have been told that in years past before the introduction of the bowtie blocks, these were sought-after by racers.
STK4340 is offline   Reply With Quote
Old 09-26-2008, 01:52 PM   #6
Mike Pearson
The small journal 327 blocks were proned to splitting cylinders if you ran them at 060 over. You would be better off with a 4 bolt large journal block. I am not sure about the 283 stuff. I have a real early 1962 small journal block in my car now and it seems to be a good one. They are real hard to come by. Sonic checking was real popular before the bowtie blocks. It was a waste to do all of the machine and prep work on a production block then have it split a cylinder after 10 - 15 runs.
Old 09-27-2008, 03:10 PM   #7
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Question Re: SBC cylinder wall thicknesses?
Why don't you guys just sheeve the cylinders? It's $80 a cyl & a hell of a lot stronger.
Old 09-27-2008, 06:39 PM   #8
Bub Whitaker
Who will do it that cheap and does that include the sleves and what material is it??
Also beware on stock SBC blocks the sleves get dangerously close to the bolt holes and almost always crack to those bolt holes... Bowtie Blocks are no problem and will work well for sleeved down for say 305 \ 283 \ 265 ...
Bub Whitaker is offline   Reply With Quote
Old 09-27-2008, 10:47 PM   #9
Tom Moock
Liked 10 Times in 6 Posts
Bub, I sent you PM, Tom
Tom Moock 5704 STK
Tom Moock is offline   Reply With Quote
Old 09-28-2008, 01:17 PM   #10
ss wannabee
Thanks guys.....what about thickness of finished bores in the early 265/283 blocks? Any ideas on this and how it compares to best 350 situation? Isn't there a small-bore Bowtie block available with an unfinished bore size of about 3.7" so you can bore/hone to the desired size instead of sleeving down for the smaller displacement racers? Bub, is that sleeve/cracking problem more common in the larger or smaller bore production blocks or ALL of them? Thanks again!
