Old 09-05-2008, 05:31 PM   #21
Wade_Owens
Wade_Owens's Avatar
Liked 3 Times in 1 Post
Default Re: B/SA Supremacy
Originally Posted by M Brand 505B View Post
Does anyone know which heads Bill Hawk Runs? large/ small valve, stock or edelbrock heads, and single or dual carb? Thanks.
I was wondering the same thing. Not being a Ford guy, I really dont know what this combo consists of. Which parts makes it "paper" instead of factory.
Wade O
Old 09-06-2008, 11:27 AM   #22
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Talking Re: B/SA Supremacy
390 type Edelbrock alum. head, small valves, with on LARGE 850 cfm holley is what he runs and its what makes it a "PAPER" combo but so what ! Its what the NHRA allows such as fuel cells, replacement alum. heads with different exhaust ports on 396 chebbies,wheelie bars, acid or media blasted ported heads, aftermarket rods with chevy rod bearing size, small lite auto trans, aftermarket stick trans, and on and on. Get over it. Its NHRA,s ball park so ya gotta play by NHRA's rules. Stock died in 1985 with the cam and spring rule change.
Old 09-30-2008, 07:18 AM   #23
Mike Fuller
Liked 198 Times in 79 Posts
Another episode in this story.
http://www.dragracecentral.com/DRCSt...r2008#indextop
Mike Fuller 396 STK
3961 SS
Old 09-30-2008, 09:02 AM   #24
Dave Ficacci
Dave Ficacci's Avatar
Liked 98 Times in 23 Posts
Originally Posted by Mike Fuller View Post
What combo does Sorensen run? He is always listed as a 427..
Dave Ficacci
1013 STK
1170 SS
Dave Ficacci is online now   Reply With Quote
Old 09-30-2008, 09:09 AM   #25
SSDiv6
Liked 1,583 Times in 582 Posts
The Sorensen Camaro is fast. I believe if he had been at Indy, unless he screwed up, he would have won class. I was close to the top end. Jimmy left first, Sorensen caught up past the 1/8 and was about 1 car ahead. I also heard a change in RPM like if Sorensen lifted at the stripe.
Old 09-30-2008, 01:14 PM   #26
novassdude
Liked 136 Times in 49 Posts
I believe the fastest is sitting in South Dakota That is where the record is at.
novassdude is offline   Reply With Quote
Old 09-30-2008, 02:09 PM   #27
SSDiv6
This was not a record setting pass for the Sorensens or Jimmy. It was a heads-up run and the corrected altitute at the track was probably around 2000+ feet.
Old 09-30-2008, 02:53 PM   #28
Brian Zenzen
i believe as it stands an older gentleman in south dakota holds the record
Brian Zenzen is offline   Reply With Quote
Old 09-30-2008, 03:35 PM   #29
Sean Cour
Guest
Posts: n/a
The air was around 3000 ft, barometer was 28.49. I'm sure if the Sorensen's want to set the record, they can.
Old 09-30-2008, 04:02 PM   #30
5919 SSKA
Liked 19 Times in 5 Posts
It's too bad National Records don't PAY---even Pts..........I think you would see a few more people throwing up big numbers and evening out combo's.
Racing web page
5919 SSKA is offline   Reply With Quote
