Old 10-01-2008, 02:46 PM   #11
5919 SSKA
Liked 19 Times in 5 Posts
Default Re: warning bg fuel regulaters
Jason----What pump are you running?
Trav
Racing web page
5919 SSKA is offline   Reply With Quote
Old 10-01-2008, 03:21 PM   #12
Greg Barsamian
Liked 427 Times in 97 Posts
I met Jeff Stacy from Aeromotive @ last years PRI. His product knowlege and the quality of they're fuel components convinced our sponsor to use they're product line.
Areomotive suggested to us that we use "micron filters" on all our fuel systems as opposed to paper or element filters. The additives contained in "race fuels" can breakdown the paper filters and the adheisives used to hold them together, thus contaminating your carburator or fuel injection system. Makes sense!
I've got (2) bad BG 400 pumps and a 2-port regulator.
BG wont sell rebuild kits, they want you to send them back to them!
They're stuff seems to self destruct after a few seasons!
I've heard from other racers about having to send remanufactured BG products back a second time!
Mark, buy the Aeromotive stuff, your fuel distribution problems will go away!
G
Old 10-01-2008, 03:36 PM   #13
J DeForrest
J DeForrest's Avatar
Liked 73 Times in 18 Posts
Trav
I have a pump for EFI (running at 60psi), maybe give them a call and see what they recommend. I believe I talked to Kyle last time. Also running a before/after filter.
Jason
J DeForrest is offline   Reply With Quote
Old 10-01-2008, 03:37 PM   #14
Chad Rhodes
I have had tremendous luck withe MagnaFuel stuff. Its quiet, less vibration, more consistent pressure. Its field serviceable, and at a reasonable clost, even the brushes are replaceable without dissassembling the unit
Chad Rhodes 2113 I/SA
Old 10-01-2008, 04:02 PM   #15
Sean Ward
Sean Ward's Avatar
Send a message via AIM to Sean Ward
This past week end at arace in georiga we had the one on our super gas car go bad after a first round win but could not make the call for round 2 cause the reg. hung up and filled the motor with fuel and the motor would not turn over bg stuff is junk it is now all areomotive all around even my stocker The people at areomotive were great to talk to and tell me witch stuff i needed for each diff. car that we have.
Sean Ward NHRA s/ss/comp#2882
SW4 MOTORSPORTS
Sean Ward is offline   Reply With Quote
Old 10-01-2008, 04:06 PM   #16
Duane Eiskant II
Duane Eiskant II's Avatar
Liked 57 Times in 33 Posts
Magnafuel and Aeromotive BOTH are tied as the best fuel pump companies out there. Have had the magnafuel pump and regulator excuse me pressure control unit (thats what they call it) on my car now 3 years with out a bit of problems. One thing i would do if you get the magnafuel and run 16 volt system is turn the bypass pressure down some.
Duane Eiskant
1354 Stock/Super Stock
Duane Eiskant II is offline   Reply With Quote
Old 10-01-2008, 04:31 PM   #17
CrateCamaro
CrateCamaro's Avatar
Liked 19 Times in 7 Posts
Originally Posted by Steve Polhill View Post
BG won't even send you a rebuild kit. They want you to send it back to them to rebuild it. I'm looking into getting an Aeromotive pump from the recomendations of several other racers..
Check online. I bought a rebuild kit for my BG280 on ebay for 20 bucks. I run a BG return style regulator and i've never had a problem. The pump its constructed like an oversize holley "blue" but its never let me down. I personally like the Mallory 140/250 style pumps and regulators. And the pump itself is a good piece...bearings no bushing.
Tony Valerio 1968 Camaro
1700 IHRA H/CM
1701 NHRA SS/?A
Old 10-01-2008, 04:45 PM   #18
Rob Petrie E395
Liked 216 Times in 77 Posts
I thought I would try to add some humor to this. Mail just came a few minutes ago and there was the Oct 3 issue of Natl. Dragster. When you all get yours look at the back cover its a Barry Grant ad and at the top it reads "Throw-Away" or Race today? They must be talking about throwing away their pump so we can go racing. LOL!
Old 10-01-2008, 05:25 PM   #19
sst1988
sst1988's Avatar
Thumbs up Re: warning bg fuel regulaters
i had my bg400 in my car since 1993 with a 2 port the only problem was the reg and at a nat meet he gave me another 2 port in exchange.
sst1988 is offline   Reply With Quote
Old 10-01-2008, 07:36 PM   #20
Mark Callanan
Liked 64 Times in 14 Posts
[QUOTE=sst1988;85409]i had my bg400 in my car since 1993 with a 2 port the only problem was the reg and at a nat meet he gave me another 2 port in exchange.[/QUOT
you are very lucky if you havent had Carry Grant problems
Mark Callanan 1027 STK
Mark Callanan is offline   Reply With Quote
