#21 |
Vic, yes the 4300D came on many 460`s, but it seems that all the 460`s in the SS/GT classes run the 74 version, which had a Carter ThermoQuad available as well as the 4300D.
#22 |
Liked 57 Times in 33 Posts
i use both needle and seat assemblies in the carb. Primary and aux, and run 9 # of fuel pressure. No flooding issues. Also since the float bowl area is so small i run a number 10 line from the regulator to the carb inlet which helps act as a log and hold reserve fuel.
Duane Eiskant 1354 Stock/Super Stock |
#23 | |
Liked 883 Times in 237 Posts
Tom Goldman 1500 SG , 1506 STK Last edited by Tom Goldman; 10-07-2008 at 05:23 PM. |
#24 |
I've always run both the primary and secondary needle and seat assemblies. I do run a return style regulator. Like I said, just under
7#'s has not been an issue. I did purchase one ofthe Gross-Jet assemblies. They sent the wrong p/n twice and I gave up. Never did get my money back either!
Jeff Lee 7494 D/S '70 AMX |
#25 |
Liked 165 Times in 59 Posts
who sell the grose assemblys???? ,like tom mentioned the rebuild kits that you get today dont have the aux needled and seat they come with a plug
#26 |
Liked 333 Times in 180 Posts
gmonde--I sent you a PM--Comp 387
#27 | |
8 Mount Vernon Street Stoneham, MA 02180 (781) 438-1789 ...also, contact Larry Fulton at Hot Rod carbs... http://www.hotrodcarbs.com/precisionFlow.html |
#28 |
Tom, i made my needle and seat. Use the same needle and drilled the seat bigger i think i got it like .120 or so cant really remember. Havent had any problems with it so ive left it alone. The aux needle and seat assembly was in the carb and ive never changed it.
#29 | |
#30 |
Same thing I did on mine, drilled to .120". .......I'll have to see if I can scrounge up an aux needle and seat to try. I typically run 7#, 9# in good air with just the one inlet, but I know when I jet it up in really good air,it tends to nose over at about 1200'.. .....You can see the A/FR go lean at that point,so the aux valve will definately help .....Suprisingly this is the most anyone has been willing to talk about these carbs. .....The few Ford guys who run them are usually very protective of their info. ........Tom
