Liked 39 Times in 5 Posts
Anyone have experience in the value of a spool versus a posi unit? I currently have posi in a L/SA 305 Malibu and am wondering if it would be a cost effective upgrade.
Norm Webber |
Glad you posted this question. I have been wondering the same thing as I build my T/SA 231 V6 Starfire. I assume the answer will be about how much HP one has. Or maybe car weight. Or maybe both?
Rick |
Guest
Posts: n/a
My opinion: Either will drive both tires (as long as the posi is functioning properly). I have a friend with a J/SA Pontiac with a posi. Video shows what we suspected, it needs to be rebuilt as the right rear doesn't seem to be engaging properly. We're going to replace it with an aluminum spool. On a low HP application (maybe I should say low torque), I believe every effort should be made to reduce every once of reciprocating weight in the trans, driveshaft, rear-end and wheels / tires. If it were my car, that's what I would do!
Good luck... NHRA #7494 SS/H 1970 AMC AMX "Best Appearing" @ NHRA '06 Pacific Sports Nationals JeffLeeAzRealty@Qwest.net 602-418-9797 |
Liked 70 Times in 22 Posts
Jeff
Might want to reduce the rotating weight too.
Stewart Way 2424 SS |
Thanks for the responses. So if money is a factor which would be a better investment, spool at a 10 pound savings or a metric 200 trans?
Norm Webber |
Liked 54 Times in 33 Posts
Friction is what you want to reduce. In a low hp combination why have a spool. When you use a spool you're always seeing more friction. All you need to do --- is make the car hook.
I miss step. |
I highly recommend to go to a spool. posi will have some give no matter how well it is. you don't want it to cause the car to launch to right. plus a spool is lighter.
Liked 56 Times in 27 Posts
![]() Back to what Jeff was refering too, have you ever see a car spinning just one wheel and the other is glue to the track ???? How can you tell when this is going to happen, do it right the first time, its cheaper in the long run...Plus weight and durability...LOL Dave...1033/stock(350) RV-455
Dave Ribeiro 1033 STK |
Spool is the way to go just be careful if the staging lanes are wet because the car wont like to turn. I know.
Liked 1,604 Times in 583 Posts
Also, make sure to check the front end chassis/alignment too.
