Old 05-09-2007, 09:43 PM   #1
Mike Coates
Guest
Posts: n/a
Default Mopar AVS help
I need a little help in getting my AVS to work right.
I am running a 70 340 in Pure Stock. I have a stumble / bog on the launch that I can't fugure out how to get rid of. I am not an expert on carbs, so any help would be appreciated.
I have tried different accelerator pump linkage positions, larger and smaller squirters, larger jets and adjusting to the air valve. None seem to completely cure the problem. The air valve seems to help best, if I put enough preload on the spring, but the stumble is still there.
Any suggestions would be appreciated.
Thanks
Mike Coates
IHRA 3914 D/PS swinger
Mike Coates
Old 05-09-2007, 10:44 PM   #2
SSDiv6
Liked 1,583 Times in 582 Posts
Default
Call Dean Oliver:
http://www.retunedmusic.com/deano/
Old 05-10-2007, 01:12 PM   #3
MFR440
Liked 13 Times in 5 Posts
Default
Thanks
Mike Coates
Mike Coates
Been a while since we ran the AVS's, but you might try closing up the oval-shaped holes in the flappers, if it's legal of course. This helped throttle repsonse with our Max Wedge. We used duct tape at first, then epoxied wire mesh over the holes.
Meyer Family Racing
'64 Plymouth Max Wedge
'65 Dodge - rebuilding for ??
N/SS S/ST & H/R 3426
Meyer Family Racing (re-tired)
1965 Dodge Coronet - Steet car and Part-time N/SS
1962 Plymouth Fury S/ST #3384 - Race in Peace, Craig Meyer
MFR440 is offline   Reply With Quote
Old 05-10-2007, 03:24 PM   #4
John Dinkel
Liked 263 Times in 68 Posts
Default
Make sure the air valve is tight enough. 1 1/2 to 2 turns should help.
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
Old 05-10-2007, 09:24 PM   #5
George Mirza
Default
Try a new spring on the air valve, sometimes when they are weak the door will snap open and not open gradually. I chased that problem on a TQ, new spring stumble was gone. AVS's can be tricky, they don't have a vacuum diaphram to delay the air valve opening.
Also the carb may be to lean, try jetting up the secondary side.
Make sure the primnary's are open 1/2 - 3/4's before the secondaries. I had one that must have been a marine unit and the primary's would open about 1/4 and the sec. would start to open. I tried everything and could not get the stumble out. It was the only AVS I ever saw that did that.
Chuck Beach is the guy to talk to about AVS's.
When you get one right it will work great.
GEORGE MIRZA STK 1236
George Mirza is offline   Reply With Quote
Old 05-10-2007, 11:45 PM   #6
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
Default
Hey George, Whats cookin
Paul Precht is online now   Reply With Quote
Old 05-11-2007, 12:33 PM   #7
Mike Coates
Guest
Posts: n/a
Default
Thanks everyone for the input!!
I will try out the suggestions and determine where to go from there.
Thanks again!
Mike
Mike Coates
Old 05-11-2007, 10:39 PM   #8
George Mirza
Default
Hey Paulie, long time no see!
I don't get out as much as I used to. Hows life in PA? I still see Lenny once in a while and Howard and I still run quite a bit up here. The only race we go to down your way is the Dutch. I miss the Mopar Nats.
How about yourself, your in the thick of it now, when are you going to get out.
George
Old 05-12-2007, 07:34 PM   #9
Chuck Beach
Chuck Beach's Avatar
Liked 58 Times in 13 Posts
Send a message via AIM to Chuck Beach
Default
I have worked on these carbs for about 30 years, part of the problem is the accerator pump, I make my own. I can send you one for about $30.00. I run a '68 340 cuda in G/SA, have gone 11.0's, but I leave on a 2 step, but can still go back to foot braking. The secondary air valve needs to be tight, if it binds up, replace it with another one. If you want me to go thru it I charge $350.00. good luck
Chuck Beach
3340 STK
Chuck Beach is offline   Reply With Quote
Old 05-14-2007, 07:28 PM   #10
Glenn Person
Default
Chuck , Would you send your email to me at aaaltd@sasktel.net Would like to talk about an AVS. Thanks Glenn Person
Glenn Person 5356 STK
Glenn Person is offline   Reply With Quote
