Old 11-25-2008, 06:51 PM   #1
J Kuchel
Banned
Question Rebuild 1969 Camaro frontend
I need some good advice on rebuilding my 1969 Camaro drag car frontend. The engine and trans is out of the car, is it easier to rebuild with the engine in or out? I want to put all new steering componts on the car. What a arm bushings to use? What brand is every body using for tie rod ends,center steering link ect... Also what brand of front springs? Any help on setting up the frontend would be helpful. Thanx and have a great Holiday.
J Kuchel is offline   Reply With Quote
Old 11-25-2008, 09:20 PM   #2
40Coupe
Default Re: Rebuild 1969 Camaro frontend
You have a PM.
'67 Camaro
1.25
5.77 @ 118
40Coupe is offline   Reply With Quote
Old 11-25-2008, 10:34 PM   #3
J Kuchel
Banned
Talking Re: Rebuild 1969 Camaro frontend
Thanks for the PM. Appreciate the input.
Old 11-25-2008, 11:04 PM   #4
Most of the stuff in the steering linkage is often Moog or TRW. Most of what is seen in A arm bushings is Del-A-Lum or other Delrin stuff, although there are some using bearings. There's a longer upper ball joint that helps geometry a lot, it's commonly found in circle track stuff. Springs depend on the combination.
Old 11-26-2008, 02:09 AM   #5
Sean Kennedy
Sean Kennedy's Avatar
Send a message via AIM to Sean Kennedy
Originally Posted by 40Coupe View Post
You have a PM.
This is happens a lot, and it is very frustrating.
I monitor these tech forums to try and learn.
I don't see why people think information is so secret that they can't post it on the forum for all to read.
Sean Kennedy is offline   Reply With Quote
Old 11-26-2008, 09:56 AM   #6
mannymen
Liked 13 Times in 7 Posts
Sean Kennedy I hear you. I also wonder the same question. If someone is willing to help one person then why not all.
Gary Wisecarver sells the upper/lower control arm bearings and a quality aftermarket tie rod tube will do. I think Hotchkis and Global West sells them. Ball Joints were already mentioned above
Moog will have the rest.
Pitman arm
Idler arm
Centerlink
Inner/Outer Tie Rods
N/A
mannymen is offline   Reply With Quote
Old 11-26-2008, 10:04 AM   #7
mannymen
Smile Re: Rebuild 1969 Camaro frontend
One last comment.
If ANY of you see me at the Div 3 races (NHRA/IHRA) and need help just stop by and ask. I'll help out as much as possible and I hope any info will be worth a damn to you, but no guarantees it will help
69 Camaro (Blue) running SS/BA or CA and setup to BRACKET RACE in Super Stock
N/A
Old 11-26-2008, 10:14 AM   #8
Bobby Zlatkin
Bobby Zlatkin's Avatar
I find it easier to do front end work (springs, control arms) with the motor in.
The extra weight works to your advantage.
Bobby & Norene Zlatkin L/SA
Bobby Zlatkin is offline   Reply With Quote
