Old 06-28-2008, 06:17 PM   #11
Joe Martens
Joe Martens's Avatar
Liked 198 Times in 71 Posts
Default Re: Front Suspension help
Mike Pustelney from MPR is a QA1 dealer and can get you a good deal on them. His # is 810-798-8998.
Joe Martens AA/Stock 3969
Joe Martens is offline   Reply With Quote
Old 06-30-2008, 05:46 PM   #12
etracr
I spoke to a few people about the travel in my front end. They had mentioned that i should cut a few coils off the springs ( a little at a time of course ) And i can gain my front travel that way. My question is how low is too low? Also should i put some snubbers on the LCA`s as i dont have any right now.
Still no feed back on the ball joints?
I ordered the shocks today, they should be here wed and i will test them on sat. (its a points race so im hoping i dont need to fool with them too much initially) Any comments on starting points for the shocks? I will post my results from sat with the new shocks also!
Thanks again guys really appreciate it!!
etracr is offline   Reply With Quote
Old 07-01-2008, 11:12 PM   #13
NovaMan
NovaMan's Avatar
Cutting coils will help by lowering the frame in relation to the upper control arm, but if you cut alot, you also make the spring stiffer. I like to be able to get a regular jack under my front subframe, but that's just personal preference.
Getting longer lower ball joints doesn't gain you any suspension travel. Snubbers on the LCAs might not help you, but I doubt they'd hurt you.
~Pete
1970 Nova
NovaMan is offline   Reply With Quote
Old 12-28-2008, 10:47 AM   #14
72Malibu
72Malibu's Avatar
Snubbers on the lower control arms help cushion the landing!!! Have you trimmed the snubber under the upper control arms to gain travel? Is there any more feedback on a the QA1 "R" series shocks, is the fixed "firm" compression enough to withstand 2-3' foot wheelie landings? I'd love to get a pair of Santhuffs to go with their springs, man those things are pricey!!
*** 72 Malibu ***
1.329-3.99-6.28@106.71-9.98@131
best 60ft to date-1.2997
72Malibu is offline   Reply With Quote
Old 12-28-2008, 07:08 PM   #15
Dave Jung
Dave Jung's Avatar
Liked 5 Times in 5 Posts
Can you use the bolt in upper ball joint spacers in NHRA stock eliminator? I Have them in my bracket Camaro, and they work great. They increase my front end travel quite a bit. Just wondering if they are legal. Thanks, Dave.
6535 stk
81 Malibu K/SA
Dave Jung is offline   Reply With Quote
Old 12-29-2008, 03:00 PM   #16
Mike Pearson
Mike Pearson's Avatar
Liked 1,966 Times in 595 Posts
Who makes the ball joint spacers or the long ball joints for an early Camaro
Mike Pearson 2485 SS
Old 12-29-2008, 07:27 PM   #17
Check the circle track suppliers.
Old 12-30-2008, 12:22 AM   #18
njk53
Companies like Longacre, BSR, or Ed Howe of Howe Racing
(Michigan) probably would have them. I would try Ed Howe first, he does a lot of oval track chassis stuff.
Nelson Kowal
Stock 345
