Old 01-07-2009, 09:43 AM   #21
Liked 1,830 Times in 415 Posts
Default Re: Runner Volumes
No thanks, I'll pass. I have no desire to see or participate in "aftermarket GT crate motor crossbred stock eliminator".
Old 01-07-2009, 10:03 AM   #22
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Talking Re: Runner Volumes
I guess you will be staying home or taking up Golf or some other activity then as "ITs A Coming". Soon to theaters near you. In some cases its already here with the Edelbrock heads on the 390/428 Fords and others.The hand writing is on the wall already.
Old 01-07-2009, 10:16 AM   #23
Bruce Noland
Liked 444 Times in 145 Posts
X tech man
I know you are a purist about this tech stuff but nhra is never going crate motor racing.
Bruce Noland 1788 STK
Old 01-07-2009, 10:22 AM   #24
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
What's the deal????? We already have specs that we have been working with for years - carbs, combustion chamber volumes, bore, stroke, etc. If you find a carb in the junk yard that is over size on spec, you don't use it 'cause you know it won't pass tech. Same with the runner volumes. Don't use a head that won't pass or make it pass. Just because we haven't had a spec for runner volumes before is no reason to get your shorts in a wad. Deal with it like everything else. If you think NHRA's spec is wrong, appeal the best you can. If you have spent maximum $$ for a heads that are now illegal, such is the environment of NHRA class racing. This area has been an issue for years and now that Glendale has spoken, you have your supper on your plate. Are you going to eat it or starve? Since the way they have dealt with the SRAC is very telling about their procedures, your belly-aching probably is a waste of energy.
The "measure and add 1 or 2 percent" idea was used during the establishment of the current SS specs. Maybe not consistently across the board, but that was the intention so that there would be some cushion. Of course, you had some enterprising factions who made their ante over the top during the time the tech people were gathering data, but many of the current specs have a bit of extra built in. I'm sure there are exceptions.
Old 01-07-2009, 10:50 AM   #25
art leong
Originally Posted by Bart Kilraine View Post
We pay a horsepower penalty for those heads,I'd rather run the steel heads.The runner volumes are bigger in the after market heads......that's why the horsepower difference! All you people finding all these heads with way bigger volumes listed, since the '70's are mostly full of ****.
Bart I used to feel this way to, but not as brazen. But I was not up to snuff on the valve changes and the bottom angle (bowl porting) vavle jobs. Now allowed by nhra. It is totally possible that a stock (unmassaged) head can go over the cc's. If I had a (really) legal head and it was kicked out because of what nhra allowed me to do I would be more than upset.
On the other hand the massaging of the head stuff started back in the 70's and has been a snowball rolling downhill ever since.
Art Leong 2095 SS
Old 01-07-2009, 11:32 AM   #26
X-TECH MAN
Banned
Originally Posted by Bruce Noland View Post
X tech man
I dont blame them.....they have enough people throwing $$$$ at them already and the pits wouldnt have the room for all of them if they did......lol.
Old 01-07-2009, 12:28 PM   #27
hadtobethere
Exclamation Re: Runner Volumes
What's the deal????? We already have specs that we have been working with for years - carbs, combustion chamber volumes, bore, stroke, etc. If you find a carb in the junk yard that is over size on spec, you don't use it 'cause you know it won't pass tech. Same with the runner volumes. Don't use a head that won't pass or make it pass. Just because we haven't had a spec for runner volumes before is no reason to get your shorts in a wad. Deal with it like everything else..............
The "measure and add 1 or 2 percent" idea was used during the establishment of the current SS specs.............I'm sure there are exceptions.
You hit the nail on the 'head'......Stockers have known for years what the SS head specs are, and NHRA should have had their heads out of their XXX's and used these specs for stocker guys from day one.....After you guys used all of the tricks the SS guys used to do and then added bowl cuts, trick valves, etc, now you got 'BIG heads....cause NHRA now says, we are going to use the SS specs for Stock....I think most of you guys always knew that someday NHRA was going to do exactly this.
hadtobethere is offline   Reply With Quote
Old 01-07-2009, 12:33 PM   #28
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
Originally Posted by Dick Butler View Post
New 207 carbs, New Aluminum heads for big blocks, New cranks, new rods new pistons to spec sheet. New Blocks for strength. We are there now we just need to find a company who wants the work. World might be the one to do it. Why buy old rusty castings and spend the work to be off on CCs and worse create all this foolishness of tech currently sees. Make some good ones with todays technology and move forward. Cut the crap and cost at the same time.
I hate to say it but I think making one casting for small block low pro and one for high compression for ALL stock and SS would be the smart way to create the large number needed to justify making them. Simplify tech and stop the frustration in tear down.
One casting of any family of motors the same thing. Just think it would also help stop the tech book finding an obscure combo wrongly factored and ignored by tech for 5 years too..
Thanks for listening... Dick
Welcome to CHEVY Stock Eliminator.Brought to you by NHRA and George Orwell.The way tech is going just let the federal govt. take over,they couldn't *#@# it up any worse than the morons in Glendora.
BYE bye S/SS.
Ed F.
Former NHRA #1945
Former IHRA #1945
T/SA
Old 01-07-2009, 12:42 PM   #29
Bruce Noland
This is probably a discussion for the racers only forum on this site, because we have too many non racers and no names out here mixing it up with current racers on this issue.
Old 01-07-2009, 01:06 PM   #30
bsa633
Banned
Question Re: Runner Volumes
""In addition, cylinder head runner volumes will be monitored during 2009. Runner values may not exceed the current Super Stock Cylinder Head Volumes as listed on www.nhra.com.
Regardless of the poured volume measurement, any modifications to intake and exhaust runners are prohibited. Any evidence of modifications from the original castings will be grounds for disqualification. Final decision at the discretion of the Technical Services Department.
A revised list of Stock and Super Stock accepted runner volumes will be adopted for the 2010 season ""
Is that last sentence still in effect? If so.. why would they DQ. Stockers acc. the current SS list this year of 2009 if they then possible could be legal 2010?
bsa633 is offline   Reply With Quote
