Old 01-10-2009, 09:32 PM   #1
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Default SFI Scattersheild meeting
This was just posted on UMTR
Posted - 01/10/2009 : 3:59:08 PM
The following are the minutes from a SFI meeting, where the main discussion was the possible acceptance of a window in a 6.1 passanger car bellhousing
Specification Review Meeting Minutes
Bellhousing Committee – Specs 6.1, 6.2, 6.3
Friday, December 12, 2008
Performance Racing Industry Show
Orange County Convention Center – Orlando, FL
Attendees
Kyle Jackson DHRA
Gene Mohney NADM
Brian Browell Browell Bellhousing *
Ross McCombs Quicktime, Inc.*
William A. Pasco III Lakewood*
Jim Puskas Lakewood*
Dave Flory ProBell Racing Products*
Tim Hyatt Hyatt Racing Services*
Mike Miller Trick Titanium*
Arnie Kuhns SFI
Jennifer Faye SFI *denotes committee member
SFI President and CEO Arnie Kuhns called the meeting to order at 1:00pm. It was explained that existing specifications must be reviewed on a periodic basis to ensure their relevance to current field conditions. It was previously asked of the committee to submit in writing any suggested agenda items prior to the meeting. It was noted that attendance for this committee did constitute a quorum, therefore official business could be conducted. The comments of those in attendance would be heard and a report will be provided to the full committee.
The committee began by discussing the one agenda item that had been previously submitted: allowing a lower adjustment slot in a 6.1 bellhousing that would enable access for adjustable clutches without end users making their own holes or improper modifications to the bellhousing.
This would be for passenger car replacement bellhousings only. It was suggested to create a new separate spec for this application, such as 6.1W (for window). The following are all items that the committee would like incorporated into a draft:
In such a new spec, the window should be reinforced. The new spec would omit the wording about the adjustment opening being located past the rotating clutch assembly. There would be a separate sticker on the window itself. The window should be as close to the transmission end of the bel lhousing as possible, such as a 6.2.
It was asked what kind of clutches these bellhousings would be used with. It was stated it was mostly for Stock and Super Stock class cars and a dual disc would be the most discs they would use, with a relatively small diameter.
The bellhousing with the greatest depth would be tested to cover all like models.
The committee needs information for possible assembled clutch heights. Tim Hyatt volunteered to compile this information.
The committee needs to determine dimensions for the smallest useable hole size based on this clutch data and a shallow bellhousing.
The window will have to be located on the lower quadrant because it’s for a passenger car application.
The spec should require a recertification life to prevent unauthorized modification (1 or 2 years).
The window should be an oval-shaped hole.
Tim Hyatt volunteered to send the clutch info he acquires to SFI for distribution to the full committee. SFI would then coordinate R&D testing with the manufacturers.
The committee will then meet mid-year 2009 to review its findings. A possible location would be during the NHRA Norwalk race in June.
The committee had no other items to discuss regarding Spec 6.1.
Next the committee addressed Spec 6.2. It was pointed out that a 6.2 bellhousing is tested with a flywheel with ring gear, but in actual use, there is no ring gear installed. It was proposed to revise Spec 6.2 to use a test flywheel that has no ring gear. The committee voted and unanimously passed this proposal. The proposal will be sent to the SFI Board of Directors for final approval.
There were no other items to discuss regarding Spec 6.2.
The committee had no items to discuss regarding Spec 6.3.
With there being no further business, the meeting adjourned at1:35pm.
Respectfully submitted,
Jennifer Faye
Program Manager
Sean Marconette
84 Mustang
5060 SS/N
Old 01-11-2009, 06:30 AM   #2
james schaechter
Thumbs up Re: SFI Scattersheild meeting
That would be a great deal! I have talked to several on this issue, but never dreamed SFI would even hear it. I sure hope it happens. Changing counterweight without pulling the bellhousing would be a real treat!
My brother and I put a QuickTime bellhousing on our car this year and it is very nice. It is steel, but it is smaller, fits better and is 12lbs lighter than the Lakewoods that we had been running. I have some pics of it if any stick guys are interested. PM me or e mail. jimschaechter@earthlink.net
James Schaechter 3163 STK
Old 01-11-2009, 10:14 AM   #3
Greg Barsamian
Liked 427 Times in 97 Posts
Default Re: SFI Scattersheild meeting
Why not a 5-year certification on a Scattershield with a window?
Old 01-11-2009, 11:28 AM   #4
LB Racing 3179
Jim, I am having trouble getting e-mail to you. Could you send some pictures of the bellhousing to me. Thanks Fastman68@aol.com
LB Racing 3179 is offline   Reply With Quote
Old 01-11-2009, 01:19 PM   #5
SSDiv6
The problem at SFI is Arnie Kuhns...he needs to be replaced by some one with a lot of more knowledge and common sense.
Old 01-11-2009, 07:57 PM   #6
Cam
Cam's Avatar
Greg:
I agree.
Can anyone explain the logic behnd 1-2 year certs on S/SS scattershields?
" The spec should require a recertification life to prevent unauthorized modification (1 or 2 years)."
Cam
Cam is offline   Reply With Quote
Old 01-11-2009, 08:58 PM   #7
55 Chevy
55 Chevy's Avatar
Liked 20 Times in 15 Posts
good for only two years if this is approved?
55 Chevy is offline   Reply With Quote
Old 01-11-2009, 08:59 PM   #8
55 Chevy
55 Chevy's Avatar
So would that make my scattershield I just purchased(without an adjustment hole) good for only two years if this is approved?
Old 01-12-2009, 11:47 AM   #9
Jeff Lee
Jeff Lee's Avatar
What they are saying is 6.1W would require re-cert sooner than the 6.1. W for "window"" bellhousing.
See www.quicktimeinc.com for their bellhousings. What Jim said was correct, nice, light bellhousing. More floor space too.
Jeff Lee 7494 D/S '70 AMX
Old 01-12-2009, 01:33 PM   #10
John Kelley
WOW...they even clain to "INCREASE HORSEPOWER" too....
Just like "PICKLED" heads and intakes I guess !!!
John Kelley is offline   Reply With Quote
