#201 |
Liked 444 Times in 145 Posts
Ed,
Only you.
Bruce Noland 1788 STK |
#202 |
Liked 2 Times in 1 Post
Every car ever built was a factory experiment.
#203 | |
Liked 2,354 Times in 554 Posts
#204 |
One aspect that hasn't been discussed in this thread is the effect the supercharger will have on those cars at an altitude track. Those of you in the Eastern U.S. don't have nearly as many of those as we do out West. If you're getting blown off at sea level by one of these cars how much further behind are you going to be in thin-air against a forced-induction vehicle?
I'm not railing against the Cobra Jets. I think it's fantastic that the factories are injecting new technology into both Stock & Super Stock, but I worry that the playing field won't be entirely level. I never understood the uproar over injected cars vs. carbureted cars. As it turned out, there wasn't as great of a difference in performance as many feared would exist. Perhaps this is the case here, though I don't believe it to be so. I don't currently have a "dog in the fight" so to speak, but 430 HP seems a little low. If these engines are indeed making 700+ HP (I have no doubt that they are capable of doing so...), then 3395 lbs in AA/SA and 3610 in A/SA seem a tad light. These cars will be capable of bettering the -1.40 number required by the AHFS out of the box, but I guarantee you won't see one go that fast for a couple of years. The system remains the problem, not the car(s). A truly "automatic" system without any degree of human input will never effectively maintain a level playing field. Systems can be manipulated. Common sense cannot.
Jared Jordan 9 B/SA 2024 Jeg's D7 All Star - Stock |
#205 |
Banned
Exuse me for being a little "slow"..but is it the "Roush car" that will be at Pomona or the "Cobra Jet" like NHRA says on thier page..i am a little confused...maybe this is going to be the same as the old Shelbys..what combo of the week are you running?..small valve,big valve,Dove,Edelbrock and so on..
#206 |
Liked 584 Times in 94 Posts
Jared, That's where the fun's gonna begin!!!! Superchargers!!! OMG!!! I can't wait to get my hands on one. Just a quick "romer' ( CNC ) trace of the rotors and away we go!!! Change the Helix a degree or two ( they'll never see it ) Seal the hook with nylatron ( it's probably an air lock design) and Teflon tubing in the valleys, just for starters. Then seal the end plates , also with nylatron. We'll cryo must of the internal parts then coat them with some type of teflon/moly coat. We'll get the intake charge down about 20 - 50 degrees. Even run it slower than designed, make it efficient out the ***!! It'll make enough boost to blow the crank out of it with VP -C25. Limit us on pullies? Who cares? This is gonna be fun! (And if you think they don't know what's going on with electronics?) Just wait.............
#207 |
Gump, You would think if factor on Bruces camaro was that soft there would alot more of this combo out there. I would guess more like hard work on his part !!!
Doug Frazier D/SA 2038 |
#208 | |
Conspicuous by its absense in the blueprint specs is ANY specification on the Eaton Supercharger. No Part numbers, inlet size, dispalcement, outlets deminsions,rotor helix, case clearances or pulley sizes. No reference to factory boost levels.
Chad Rhodes 2113 I/SA Last edited by Chad Rhodes; 01-19-2009 at 10:51 PM. |
#209 |
I'm not doubting that he has worked hard and I really doubt that it is under factored now. What I was getting at was that it was just a little bit under factored (in regards to Stock Eliminator) as delivered from GM. IMO the same applies to the Cobra Jet.
#210 |
Liked 239 Times in 94 Posts
The Cobra Jet really is an 08 Shelby GT500 with less weight and a few racing modifications already done, some normally allowable in Stock and a few that aren't. A GT500 would be legal already, they've built thousands. Ford doesn't really need many of the mods to sell the car to racers who can change that stuff.
I think it'll be interesting to see what happens. |
