Old 02-12-2009, 08:04 PM   #1
Liked 1,928 Times in 434 Posts
Default Re: Stocker pin dia.
Originally Posted by RJ View Post
There are plenty of .945" rods available, but none of them made the list. So the legal rod with it's .927" pin and pin bore supersedes the stock diameter pin requirement?
The question is how many aftermarket rods with the correct pin diameter were available when the first aftermarket rods were accepted for the application. I do not know the answer.
I'd say you should probably call Wesley Roberson to make sure that you would not have to open the rod up 0.018" to accept a 0.945" pin.
Old 02-13-2009, 08:48 PM   #2
Bub Whitaker
Look on the Rod list, it says this...(Must use OE size pin or larger) for stock, regardles of how it is produced you gotta keep the size on the piston sheet.or larger ...
Bub Whitaker
Bub Whitaker is offline   Reply With Quote
Old 02-14-2009, 02:29 PM   #3
Jeff Lee
Jeff Lee's Avatar
In know from experience, if NHRA provides an aftermarket rod and the pin size is different than OEM, you are allowed the aftermarket size that the rod is built around. This is due to most aftermarket rods being built around a .927" pin and 2.100" large end as most aftermarket rods are built off a SBC blank.
Jeff Lee 7494 D/S '70 AMX
Old 02-14-2009, 04:06 PM   #4
Chuck Norton
Liked 89 Times in 19 Posts
Jeff,
In my experience a couple of years ago, we were advised that we had to keep the original pin size as per Bub's post. The motor in question was a 307 Oldsmobile that had an approved 6" Chevy rod but we were told that we had to use the stock pin size (.990 as I recall) in order to be legal. I haven't heard of that rule being rescinded.
c
Chuck Norton is offline   Reply With Quote
Old 02-14-2009, 07:56 PM   #5
Jeff Lee
Jeff Lee's Avatar
Originally Posted by Chuck Norton View Post
Jeff,
c
Been down that path w/ NHRA. FE Ford and AMC are two examples I know of. There's not enough material left in the approved rods (stress approved rods)if you run the OEM size pin. That was from Glendora.
Old 02-16-2009, 11:12 AM   #6
BRUCE PARSONS
Banned
If you go to the complete piston and rod list, the LS1 piston has been approved with the .927 pin. Also the piston is approved with 1/16 1/16 3/16 rings, with optional 1.2 1.5 2.0 ? rings. I guess you can't believe anything NHRA tells you, even if its in writing!!
Bruce
BRUCE PARSONS is offline   Reply With Quote
Old 02-16-2009, 07:12 PM   #7
Bub Whitaker
Bruce
I think your correct Bruce... all you need to do is build it, look at (ALL) the sheets...copy and bring them with u to teardown. and hope they don't change their minds,,, again
Bub Whitaker
