Old 02-15-2009, 08:42 PM   #1
Just Observing
Default Re: Next Debate.
I dont think any of this boost pressure inspection will ever happen. # 1 the tech crew has been short changed 10 % of thier nothing pay for what they do now. # 2 here in Div 1 I think they have been told to cut out 3 employees from the crew at each race (not sure about the other divisions), Tech will be almost non existant it seems. Its not even a little bit fair to run cars like these supercharge CJ's heads up with the older muscle cars (FI or Carburated) in the same class. They make thier own atmosphere (cylinder pressure) for the intake charge. They may be what detroit produces today but they will put ALL of the rest of you out of business if they continue to run in the same class. $50,000 + stockers and S/S'ers will become worthles expensive bracket cars when someone decides to run one in S/S also. 2 different technolgies involved here.
All very true! Boost vs NA is a no contest! Hopefully NHRA realizes that the CJ's are severly underated and changes hp rating to 500hp. Just like they did with Butner's boosted comp car a couple of years ago. I think they lowered his index .5 tenths or so after they underestimated it the first time.
A min. wt of 3920 lbs in AA/s(a) should slow those CJ's down enough.
Just Observing is offline   Reply With Quote
Old 02-15-2009, 09:46 PM   #2
goinbroke2
Liked 404 Times in 158 Posts
[QUOTE=
A min. wt of 3920 lbs in AA/s(a) should slow those CJ's down enough.[/QUOTE]
Yup, that'll learn 'em huh?
OK, what about the 300hp turbo 2012 cobalt? or the 400hp supercharged 2013 neon? Oh yeah, saddle them with 1000lb's, yup that's thinking.
Then the factories go "eh, screw em, lets go back to sponsoring funny car and nascar"
Good plan, lots of forethought!
How about some creative/helpfull/insightfull idea's for a common problem instead of harping time and again against fords! If this was truely about supercharged or turbo vehicles being a problem then every freaking thread on this site wouldn't degenerate back to "the cj's"
It's losing a lot of the credibility when certain people keep whining about one vehicle. Is it a cj issue or is it a super/turbo issue?
And for those with the narrow/short sight that think it's solely a cj issue, will you be here next year fixated on the next factory car? Challenger? Camaro? One at a time you'd rather whine then go for the problem/issue?
Old 02-15-2009, 10:06 PM   #3
big blue galaxie
Wink Re: Next Debate.
The issue is that turbo/super cars can keep applying boost and gain advantage over the N/A competition without checks and balances; the Cobra Jet just became the object of complaint because it is ridiculously quick from the getgo and with prep can go way faster. Even the smaller boosted cars are formidable, as Mark already knows, and the modern equipment has more efficient heads.
big blue galaxie is offline   Reply With Quote
Old 02-15-2009, 10:10 PM   #4
Just Observing
The neon and cobalt will be FWD vehicles. They will have a hard time fitting in to current Af/s class at those HP factor levels. If a car is horrible underfactored it should be raised immediately. Doesn't matter if it is a challenger/camaro, Turboed/Supercharged/NA or whatever.
At the current factor of 425 hp the CJ's weigh 3355 min in AA/s(a). So a factor of 500 hp would add less than 600 lbs to them. 570lbs to be exact. This is were they will have to be once someone starts to massage these CJ's for the current AA/s(a)combos to be competitive. IMO.
BTW when the Hurst hemi cudas and darts came out of the "factory" rated at 425 hp NHRA instantly adjusted the hp factor to 500. Seems like a precedence to me......
