#11 |
Liked 1,436 Times in 299 Posts
I understand. I have seen it. I don't dispute the person getting tossed for leaking and all that, but I guess, I wonder if there is any legitimate reason not to allow dry ice in lieu of the obvious cluster it is to remove the ice and water before a heads up run. I am one of those people franticaally trying to get all of the water off of the engine too. I could see it as a legit rule change. Maybe no one has asked?
I have seen the dry ice many times, I see loads of it at Indy. I would use it too if they would let it out of the closet. LOL.
James Schaechter 3163 STK |
#12 |
Banned
#13 |
Liked 56 Times in 21 Posts
dry ice is very dangerous
Vic Guilmino 1129 STK |
#14 |
Hey Vic, please elaborate, there could be some very good reason for not allowing it, but outside of keeping it off of bare skin and not loading up the cockpit of a plane with it, I can't think of what the issue is. Help me out. I use it sometimes in my cooler to keep my food cold over the weekend and I didn't see any skull and crossbones on it. I have seen some pretty stern warnings on cigarette wrappers and NHRA loved that. LOL
#15 |
go to google and put in dry ice dangerous
#16 |
Guest
Posts: n/a
This reminds me of what the great Jim Marshall told me once at the Sports Nats in Ohio. " Back east we bring our horse power for racing and ICE for our beer
#17 |
Liked 39 Times in 8 Posts
At Maple Grove last year I was lightly admonished for having ice bags on the engine in the staging lanes. The reason being they do not want residual water leaking all over the track. And now that I've thought about it, while watching some friends go through heads-up or record runs, they've done their cool-down just outside of the staging lanes and had someone help them wipe the car down.
Mike Meier "World's most expensive DF/S" 2007 Chevy Cobalt....because suffering through owning an AMC Stocker wasn't enough |
#18 |
Liked 460 Times in 91 Posts
Jim is a very smart man.....
Bob Bender 144 O/SA 2010-2012 National Record Holder |
#19 |
Vic, this is what I found. Maybe NHRA has a specific concern. I will ask. Not a big deal since I am used to the wet ice routine, but it certainly makes me wonder. It sure seems to me that as racers, we are handling stuff a lot more dangerous than this. On a personal note, I did get my beer too close to my dry ice once and it froze up. That wasn't dangerous, but it was a tragedy.
![]() What is Dry Ice? A copy of the What is Dry Ice? brochure is available in Adobe Portable Document Format (PDF, 369KB, 2pg). Dry ice is solidified carbon dioxide. When dry ice melts, it turns into carbon dioxide gas. Carbon dioxide gas is always present in the environment, but in low concentrations. It is colorless and odorless. -------------------------------------------------------------------------------- Safely Using Dry Ice Carbon dioxide gas is heavier than air, and therefore, it can pool in basements or other low areas. When transporting dry ice, always keep vehicle windows open to bring in fresh air. The quantity of dry ice used in a regular storage freezer or refrigerator is unlikely to produce carbon dioxide gas in sufficient quantity to cause a health problem. Dry ice can readily be used to keep foods cool in those types of containers. -------------------------------------------------------------------------------- Are there any special precautions I should take when using dry ice? There are a number of important precautions to take when handling dry ice: Dry ice is much colder than regular ice, and can burn the skin similar to frostbite. You should wear insulated gloves when handling it. Wear safety glasses and a face shield if you are cutting or chipping it. Keep dry ice out of the reach of children. Never eat or swallow dry ice. Avoid inhaling carbon dioxide gas. Can I actually suffocate from dry ice? Dry ice can be a very serious hazard in a small space that isn't well-ventilated. As dry ice melts, it turns into carbon dioxide gas. In a small space, this gas can build up. If enough carbon dioxide gas is present, a person can become unconscious, and in some cases, die. Can I use dry ice in a walk-in cooler or freezer? It is very dangerous to use dry ice in a walk-in freezer, cooler, closed truck bed, or other small space with poor ventilation. A large amount of dry ice in a walk-in cooler or freezer can produce a great deal of carbon dioxide, which can possibly be fatal to someone entering that space. What are signs of being exposed to too much carbon dioxide? Symptoms of overexposure to carbon dioxide include headache and difficulty breathing, and with greater exposure, nausea and vomiting. What are some tips for using dry ice to keep foods cool? Order dry ice in the form and size in which it will be used. It can be difficult and dangerous to cut. Store dry ice in a container that allows some leakage. If unvented, carbon dioxide gas can build up pressure inside a jar or container as dry ice melts. How much dry ice will I need? The quantity of dry ice you will need to maintain temperature in a storage freezer or refrigerator will vary. Some basic tips for using dry ice to cool foods are: In a Refrigerator: A home-style refrigerator may use about 10 pounds of dry ice per day. Dry ice may freeze items, so place foods that may become damaged by freezing as far from dry ice as possible. Place ice on the bottom of a household type unit. Place newspaper or other materials as insulation on glass shelves to prevent the shelves from cracking. Keep liquids tightly covered so they do not become carbonated as the refrigerator fills with carbon dioxide. In a Freezer: A chest freezer may use 40 to 50 pounds of dry ice per day, placed on top of the food. A home-style refrigerator/freezer combination unit. A unit with the freezer on bottom may use 15 to 25 pounds per day, placed on top of food. A unit with the freezer on top may use 20 to 30 pounds per day, placed on top of and surrounding food. A unit with a side by side freezer may use 30 to 40 pounds per day, placed on top of and surrounding food. How do I dispose of dry ice? Because dry ice can cause carbon dioxide gas to accumulate and build up pressure, do not dispose of dry ice in a sewer, garbage disposal, garbage chute, etc. Allow leftover dry ice to melt and turn into gas in a well-ventilated area.
#20 |
Liked 96 Times in 23 Posts
13 hours of drinking in the backwoods of Vermont and I thought it was called "before" making a run. Ah, what the hell do I know....
Adam Strang 1018 STK Last edited by Adam Strang; 02-22-2009 at 02:49 AM. |
