Old 02-22-2009, 07:30 PM   #1
Bob Bender
Bob Bender's Avatar
Liked 460 Times in 91 Posts
Default Re: steel or cast crank for Stock Eliminator?
Originally Posted by Joe DeMarzo View Post
Bub, that is way you are the man,
JOE YOU ARE RIGHT ......................BUB IS THE "MAN"
Bob Bender 144 O/SA
Old 02-22-2009, 08:57 PM   #2
Rory McNeil
For what it`s worth, I have a 78 Ford Fairmont bracket car with a 428 Cobra Jet and a Jerico 4 speed that runs 10.0`s at 132MPH, has gone 1.29 60 foot. All the 428 Fords came with cast cranks, I don`t rev my engine to 7000 RPM, but it does hit 6700 thru the traps. The crank is a .010" under stock Ford 40 plus year old piece, and has been in the car for 14 seasons now, never had any problems with the crank. I have the crank MagnaFluxed every 4 or 5 years when I freshen the engine, and so far, it looks like it will outlast me! I have heard that sitting on a 2 step for a long time isn`t a great idea, but I don`t normally do that anyhow. Maybe the Ford cranks are just a bit better!
NHRA 6390 STK
M/S 85 Mustang
Old 02-23-2009, 12:42 AM   #3
Dinsdale
Dinsdale's Avatar
Liked 6 Times in 2 Posts
What Rory said.. My bracket 67 Mustang is a 427 with a stock 428 crank. Jerico and 3150 lbs. Nothing fancy done to the crank and I go through the lights at 7500. So far, the crank is about the only thing I haven't broken. Car has run a best of 9.83 @ 136.78 MPH. Results with other brands may vary !!!
Dinsdale is offline   Reply With Quote
Old 02-26-2009, 11:11 PM   #4
Chris Cogan
Chris Cogan's Avatar
GM cast nodular iron cranks are stout enough for the majority of stock/super stock applications. On a 396, there is roughly 3lbs difference between cast and forged and for a 454, the wieght penalty is closer to 4lbs. I have seen numerous 468's with 2 bolt mains and cast cranks (bracket engines between 600 - 675HP) and never have I seen a broken crank.
BTW, 3 to 4 lbs off the crank is not insignificant in terms of performance. Maybe not measurable on a water brake dyno, but physics still governs our universe the last time I checked. Take care guys.
Chris Cogan
Chris Cogan is offline   Reply With Quote
Old 02-27-2009, 02:20 AM   #5
SS Engine Guy
What Bub said! And to add I have used cast cranks in S/SS cars of all kinds over the years. The most important part is to mag properly and to have someone with the experience to read what the mag is telling them. Good balance job and you are good to go. I usually run cast cranks 4 years as long as the magnaflux viewings haven't changed in 3000+lbs cars. If the balance isn't correct it dosen't matter if you have an unobtainium crank and 8 bolt mains it is coming apart. Just imagine at 7000 rpm the explosion that is going off in the bottom end when something breaks. Personally I have also seen more broken forged cranks than cast. Also just because the local machine shop has the latest greatest balancer dosen't mean that the guy operating it knows what he is doing. If you haven't ever seen or had this done, find a shop with all the BHJ block-true fixtures. The variances in a SBC will make you wonder how it ever went 10 miles in a passenger car much less a racecar. Find a company or crank grinder that can talk to you about fillet radius, crank snout runout, etc and you won't have a problem.
SS Engine Guy is offline   Reply With Quote
