Liked 230 Times in 75 Posts
Fox body Mustangs 79-93 with an auto. Who has the better struts? Single adjustable or double adjustable. Is doubles worth the extra money in a 11 to 12 second stocker. Singles are about $100 each doubles are about $450 each.
Liked 32 Times in 14 Posts
When I ran my 89 in Stock I used normal 90/10's with Moroso Trick front springs. Make sure the control arm bushings fit smoothly in the K member with no bind. I would 60' in the low to mid 1.50's when it ran low 12's in N/SA or G/FIA. Going high 11's or low 12's you dont need double adjustables IMO. For the money I would buy the single adjustables from Strange Engineering. Hope this helps.
Jay
Jay Roeder facebook.com/racefuelsales Former N/SA , Soon to be SS/AS, Renegade Race Fuel dealer Last edited by RPM5595; 02-22-2009 at 11:45 PM. |
I'm currently using QA1's.
Shawn Allsup K/S 718 |
Contact Calvert Racing, he was swapping struts quite a bit in testing the new CJ500. I'll bet he has a new product.
Jeff Lee 7494 D/S '70 AMX |
Liked 11 Times in 8 Posts
Run the Alum. bodied single Qa1's on my Edge mustang, work fine and shed a few pounds off the nose. Joe
Joe Buchanan SS/BX 3117 |
Liked 70 Times in 29 Posts
in my experience, the adjustable struts only fit an 87-up. They have larger front brakes and different spindles from the 79-86. The QA1's wouldn't fit my 84 model and Strange only lists their adjustable units for 87-up.
Chris Bowman The Mountain State Mustang 1984 Mustang GT350 |
#7 | |
It is such a common swap that Late Model Restoration even has a kit. http://www.latemodelrestoration.com/...1&comp=LRSeven |
My car is a GT 350. I had to put a ball joint on it last spring before I left for Mooresville.
I got one for an 84 GT and it did not fit. I went back and asked for one for an 84 SVO and it fit. My car, being a 20th anniversary model, must have a conglomeration of parts, but the adjustable struts still did not fit. Chris Alstons chassis works also makes a double adjustable strut for the fox body cars. I have run lakewoods on my car for 10 years.
Liked 275 Times in 76 Posts
Santuff if you have more money than you know what to do with, or QA-1's if you want the most bang for the buck. Works on my car.
Sean
Thanks everybody for the input. Still doing research don't have enough money for the Santuff or the Varistruts. The QA1 looks very good and shaves a few pounds off the front. Still have lots of work to do before the first race in May to the 90 Mustang. All ready aquired the Moroso front springs.
Wheels up everybody |
