Old 03-01-2009, 06:18 PM   #1
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Default Re: subframe connectors and stock class Q
Originally Posted by tomslik View Post
as some of you know, i'm looking at building a 67 american for stock and as there isn't any (to my knowlege) "bolt in" connectors made.
are weld in's acceptable?
what's legal, what ain't?
2X3X.083 " will be adaquate. ....The 01 body makes it easy since it's nearly a straight run to the rear rails. ....Only a short area of the floor needs to be sliced. ...You must weld the floor to the rail.......You can parallel the rear rail and just put an access hole thru it for the spring bolt. Tom
