Old 03-04-2009, 11:09 AM   #1
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Default Dana 60 w/magnetic collar
I need to talk to someone who has a Dana 60 with a magnetic collar on the rear end yoke for a tach,computer, etc
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 03-04-2009, 12:09 PM   #2
Brian Oakes
Liked 436 Times in 116 Posts
Default Re: Dana 60 w/magnetic collar
Ed, i have one on mine, email at oakes2074@hotmail.com
Brian
Brian Oakes is offline   Reply With Quote
Old 03-04-2009, 04:15 PM   #3
Ed Carpenter
Thanks for the help Brian.
Ed Carpenter
Old 03-04-2009, 05:14 PM   #4
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Ed, check with Brian on his solution. ....On mine ,I machined a .250" thick,close tolerance spacer to fit between the bearing and the yoke to get enough clearance for a Mark Williams collar. ...Tom
Tom Goldman is online now   Reply With Quote
Old 03-04-2009, 05:32 PM   #5
Ed Carpenter
Tom Brian said he bought a new yoke from Mark Williams. I was trying to avoid the 195.00. Guess not. ED
Ed Carpenter
Old 03-04-2009, 10:19 PM   #6
Tom Goldman
Ed,I used a stock type Spicer 1350 yoke. ....By spacing the yoke away from the seal by about .250" ,you can get enough clearance for a standard width ring....I used a M-W ring for a 28 spline 9" yoke and bored the id. to Dana dia. ,which I think was 2.885" .....I did mine about 10 Years ago cause nobody had a trick yoke back then. ..it's still in the car .. Even moving the yoke out by .250" there is still plenty of engagement on the pinion splines. ......Tom
Old 03-05-2009, 12:46 PM   #7
Tom Goldman
The M-W std pinion magnet ring is 1.875". as is the M-W billet yoke and the Strange chromemoly yoke. ........One more thing to consider is that the replacement yokesthat accept the collar are .500" longer than the standard Spicer yoke. ....Will you also have to shorten your driveshaft and spend more$ ? Tom.........
Old 03-05-2009, 02:37 PM   #8
Jeff Lee
Jeff Lee's Avatar
I have an aluminum driveshaft I bought used that ended up being about a 1/2" short and I'm changing the gears in my Dana 60 so I guess I can tackle all these issues at once!
Thanks!
Jeff Lee 7494 D/S '70 AMX
Old 03-05-2009, 08:34 PM   #9
Ed Carpenter
Tom Brian at Williams is telling me I won't have to do anything to the driveshaft. I bought the collar from them for the Dana 60 and he said it would fit the new yoke. I may just have my son machine a spacer at work. ED
Ed Carpenter
Old 03-05-2009, 10:42 PM   #10
Tom Goldman
Sounds like they mayhave some different diminsions than some of the older yokes. ....the Spicer one I have on the old car measured 3'' long ,and the new yokes they offer are shown at 3.500". ....You'll know right away if the collar is against the seal. ....Tom
