Old 03-09-2009, 09:52 AM   #1
Wade_Owens
Wade_Owens's Avatar
Liked 3 Times in 1 Post
Default Stocker Flat Tappet Oil....
What oil are you guys using for "dial-in" every day racing? I want to make sure to protect the camshaft from premature wear and any recommendations are appreciated. I've heard some oils dont pump the lifters up very well. Has anyone found this to be true?
Thanks for the info.....
Wade
Old 03-09-2009, 04:10 PM   #2
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
Default Re: Stocker Flat Tappet Oil....
What your looking for is oil with the highest zinc content, Valvoline and Joe Gibbs are two I am sure there are more.
Bob Pagano A/SA
Old 03-09-2009, 04:17 PM   #3
Glenn Briglio
Glenn Briglio's Avatar
Liked 973 Times in 310 Posts
Joe Gibbs oil ssems to work well.
Old 03-09-2009, 06:47 PM   #4
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
My brother-In-Law uses this on every motor he builds. He has been seeing alot of bearing problems due to lack of Zinc as well.
http://www.lucasoil.com/products/dis...%20Zinc%20Plus
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 03-09-2009, 08:29 PM   #5
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Stocker Flat Tappet Oil....
Amsoil has several high zinc content oils. These are the ones I'm sure of:
http://www.amsoil.com/adslicks/ad995.pdf
http://www.amsoil.com/storefront/rd30.aspx
http://www.amsoil.com/storefront/rd20.aspx
http://www.amsoil.com/storefront/rd50.aspx
http://www.amsoil.com/storefront/hdd.aspx
Amsoil source and info link:
www.thelubepage.com
LOCOMOTION Racing
Old 03-09-2009, 08:33 PM   #6
Chipper Chapman
Chipper Chapman's Avatar
Liked 166 Times in 71 Posts
Shell Rotella T seems to work well for me in all engines, and very cost effective too
Old 03-09-2009, 08:38 PM   #7
Brian Hansbury
Brian Hansbury's Avatar
Send a message via Yahoo to Brian Hansbury
the oil is not the cure its the additive package in it 80% of a quart of oil is mineral oil the other 20% is additives thats what makes or breaks the oil i and at least 20 other guys at my ome track have been using moa by bg for years and it works awesome
http://www.bgprod.com/products/engineoil.html
and it cost around 6.00
Brian Hansbury is offline   Reply With Quote
Old 03-09-2009, 09:19 PM   #8
Shawn Blair
Shawn Blair's Avatar
Talking Re: Stocker Flat Tappet Oil....
Rotella T and Delo 400 diesel oil work good as long as you can find some of the older stuff, I here the new diesel oil is going lower on the zinc also. I do know that Brad Penn racing oil works good, a friend of mine runs it in his stocker with alot of spring pressure and has had zero problems with his cam. We broke the cam in with Brad Penn and the GM EOS. But I'm sure there are plenty of other good racing oils to use. Shawn
Shawn Blair 6383 SS 634 STK
Shawn Blair is offline   Reply With Quote
Old 03-09-2009, 09:34 PM   #9
MHoward
Wade, use Valvoline Part# VV-850 it is 10w30 weight oil and it has good Zinc in it, I use it all the time for break-in and when I switch to (go fast oil) I dont really pick up that much,great oil.Make sure it is Part # VV-850. Most NAPA stores have it.
MHoward is offline   Reply With Quote
Old 03-10-2009, 08:51 AM   #10
Wade_Owens
Wade_Owens's Avatar
Thanks for all of the good info......
Wade
