can you run a data logger in either Ihra or nhra stock eliminator?
Liked 333 Times in 180 Posts
NHRA data recorder permitted--per page 112, 2009 NHRA rule book--- Comp 387
so would a racepak v300 work? and thanks for the help!
I use one and like it a lot, along with their guages that include digital read-out. Their reports for the data are also easy to understand/see on a laptop. It takes a little bit of time initially to get everything working. Overall I would say their instructions are very good. Technical support is excellent. It has been extremely reliable, no problems.
Liked 2 Times in 2 Posts
Does anyone have any experience with the new Autometer system?
The new Racepak Sportsman version is $699 and it looks real nice.No wires from the car to PC,uses a SD card like in your digital camera.
Nautilus Racing |
what sensors are the most important on a stock eliminator car? i know that they come with a lot of sensors like boost, driveshaft speed...etc.
Would not say these are most important, but they are some of what I monitor and track, in no special order:
o Engine RPM; o Battery voltage; o Carb Fuel Pressure; o Fuel Pump Pressure; o Oil Pressure; o Oil temp; o Trans temp; o Water temp; o Trans pressure; Would suggest if possible that you view the system you are interested in, at a race, see if someone who has one will let you look at the data you are thinking about monitoring. Also, identification of your data needs is a first step, which can be for several purposes, such as history( change in oil pressure can indicate a developing problem) or optimizing performance ( fuel pressure could be low at launch). Another example is very accurate RPM data can show engine issues. Areas you are doing R & D, and need to monitor what effect changes have. For me I have learned a lot. Hope this helps. |
Thanks for the help!
