#11 |
NHRA has a system for adjusting HP called the AHFS. The system is more difficult to apply due to sandbagging which can sometimes be attributed to running excess weight. Therefore, NHRA SHOULD mandate weight as defined within the parameters of the weight break, i.e., 9.00-9.49 equals C/S-A or SS/G-A, no more, no less.
I'd be willing to bet most, if not all vehicles with drivers can be run within those parameters given NHRA allows movement up or down a class. I would encourage NHRA to enforce such a rule. It would help the AHFS work as designed.
Jeff Lee 7494 D/S '70 AMX |
#12 |
Liked 166 Times in 46 Posts
I think what they are trying to do is make sure we don't have more than 100 lbs. of "removable" weight.
#13 |
Rocky J, I used to know a Rocky J in Jersey, you wouldn't be him would you? In answer to your question, because the Caddy is a V/8 car and can't fit a lower class then U/SA becomes it's natural class so it would be a natural U/SA no matter what it weighs above 21.99. BUT in order for it to run T/SA it should have to break above 19.99.
#14 |
Charlie, actually there is such a rule and whoever told you that is mistaken. It's right in their black and white rulebook under "Class Weight Breaks". Either they need to enforce their rules or reword the rulebook.
#15 | |
That being said, I'd hope that NHRA notices the trend of racers running significantly heavier than their minimum and doesn't allow it to become policy (if it's not too late already...). If NHRA wants to enforce this "rule" then they need to supplement the rulebook with some sort of unambiguous language.
Jared Jordan 9 B/SA 2024 Jeg's D7 All Star - Stock |
#16 |
Liked 83 Times in 32 Posts
Its very clear in the rule book
a/sa 8.00 to 8.49 b/sa 8.50 to 8.99. That tells you exactaly where you need to be. Whats the confusion. |
#17 |
#18 |
Guess that Explaines why Brandon Runs M/CM. Cant get any heavier.
#19 |
Actually Jared, it is expressed in black print on a white page under"Class Weight Breaks". By implying that there is a minimum weight I would guess that that is an implication of there being a maximum weight.
Billy Nees 1188 STK, SS I'm not spending 100K to win 2K Last edited by Billy Nees; 03-30-2009 at 05:52 PM. |
#20 |
I have seen this rule enforced at a D-4 race. If a racer books a qualifying pass at more than 100 lbs. over the minimum, he cannot remove more than 100 lbs. less than that number regardless of his minimum weight.
