Old 03-30-2009, 05:50 PM   #1
Billy Nees
Default Re: Overweight Stockers
Actually Jared, it is expressed in black print on a white page under"Class Weight Breaks". By implying that there is a minimum weight I would guess that that is an implication of there being a maximum weight.
Billy Nees 1188 STK, SS
Old 03-30-2009, 06:14 PM   #2
Jim Cimarolli
Liked 166 Times in 46 Posts
Smile Re: Overweight Stockers
I have seen this rule enforced at a D-4 race. If a racer books a qualifying pass at more than 100 lbs. over the minimum, he cannot remove more than 100 lbs. less than that number regardless of his minimum weight.
Jim Cimarolli is offline   Reply With Quote
Old 03-30-2009, 07:22 PM   #3
Boy, talk about a liberal interpretation of the rulebook. The 100 lbs is supposed to pertain to the weight box and contents. That's why the bolts don't have to be welded.
A car with a stock gas tank can carry another 120 lbs or 20, depending on preference. Still legal to burn up fuel, isn't it?
What about spare tires/ That's another 50-60. Still legal ,as far as I know.
Somebody better get to work changing the rulebook, rather than making it up as they go along.
Old 03-30-2009, 07:37 PM   #4
Talking Re: Overweight Stockers
Billy -Not hijack your thread but I did a little checking in my "archives" and found that you were right about the '77 Seville not being in the books for more than thirty years -- I couldn't tell when it was added but as of 1988 in wasn't in the Official NHRA Classification Guide..........and here I thought you were looking at it even then ! ! But if you wanted to look the '75 Honda Civic was in along with the Hudson Hornet...........
Old 03-30-2009, 07:47 PM   #5
herbjr
Liked 83 Times in 32 Posts
I have some books from 91,Ill check it tomorrow.
herbjr is offline   Reply With Quote
Old 03-30-2009, 09:42 PM   #6
Brandon Peterson
"Are you serious? You're a big boy (tall wise) but you don't look that BIG. You carry it well!! "
yup...it used to be solid muscle back in my ole football days...lol...but yeah i do
Brandon Peterson is offline   Reply With Quote
Old 03-30-2009, 10:10 PM   #7
Denny Steward
Denny Steward's Avatar
Liked 131 Times in 24 Posts
the reason I was told for your car having to fit the class you are in, is say there are 7 c/sa, 5 b/sa and o a/sa and the slowest of the c/sa cars now enters a/sa to avoid a heads up race that might happen in elims. without changing anything but the letter on the window. People that work on there cars and are fast should understand that this is the only way class racing should be if we dont start some where it will only be a matter of time before there is no heads up or quaifing and it will be just an all run bracket race
Denny Steward is offline   Reply With Quote
Old 03-30-2009, 10:39 PM   #8
SS Engine Guy
I agree as to the way the rule book reads. ie: between 8.00 - 8.500 as an example. However, that is not the way it has worked for years in S/SS. Last year I made a qualifying run behind the eventual #1 qualifier and heard the scale tech tell him he was 900lbs. heavy. At the end of qualifying he was 1.37 under. National tech and div. tech told me that was perfectly legal. Illegal would be below the minimum weigh on his sticker. I brought up what some are talking about the weight breaks in the rule book (which I agree with) and they laughed in my face. No grey areas..................you guys are right. The only thing black and white is the paper and the print.
SS Engine Guy is offline   Reply With Quote
