Old 04-06-2009, 12:10 PM   #1
CBS
CBS's Avatar
Liked 4 Times in 2 Posts
Default Re: Annual CBS Test.....@SMP
Joe.....you're always welcome.....call Nettie @ Norwalk....419-668-5555
you can have the last spot.....
Tuesday the 14th....10 to six....both lanes will be sprayed to the finish line...
Just make sure I get my parking spot........
CBS...
CBS is offline   Reply With Quote
Old 04-09-2009, 05:42 AM   #2
Joe Urbino
Unhappy Re: Annual CBS Test.....@SMP
Hey Rock,The plan I had to make the test session has fallen apart,there are way too many loose ends,most likely wont even make atlanta,so the last spot is available.hope i didnt screw things up,see you soon............Joe
Joe Urbino is offline   Reply With Quote
Old 04-09-2009, 07:20 AM   #3
CBS
CBS's Avatar
No problem Joe.....
Somebody will fill it up........
Old 04-09-2009, 11:29 AM   #4
Chaserfan Fan
Chaserfan Fan's Avatar
Hey Rock , As the day gets closer , The long range weather forcast is not to good .If it rains out can we defer to Wed or Thurs ??????
Jim
Chaserfan Fan is offline   Reply With Quote
Old 04-10-2009, 07:53 AM   #5
CBS
CBS's Avatar
yes if it looks bad we will move to one of the next 2 days....
Old 04-12-2009, 10:54 AM   #6
Gerber3533
...So, with the weather forecast still the way that it is - Should we be counting on Wednesday??
Gerber3533 is offline   Reply With Quote
Old 04-12-2009, 07:19 PM   #7
CBS
CBS's Avatar
We will make the call tomorrow....Nettie at Norwalk can give you info on getting in on wed or thurs...
thanks....
CBS
