Old 04-20-2009, 09:31 PM   #1
partsbob67
Liked 79 Times in 11 Posts
Default shims for 5.0 pedestal rockers
what is the best to use for shimming my rockers? any help is greatly appreciated.
bob beals 7244
partsbob67 is offline   Reply With Quote
Old 04-20-2009, 10:59 PM   #2
6031 stock
Default Re: shims for 5.0 pedestal rockers
have always used brass shim stock in varing thichnkess (sp)
Marshall Greenwell K/SA
6031 stock is offline   Reply With Quote
Old 04-20-2009, 11:16 PM   #3
john bertges
ford motorsport,crane cams and comp cams make shims for this this adjustment
john bertges is offline   Reply With Quote
Old 04-21-2009, 09:52 AM   #4
Rory McNeil
Don`t forget that as of this year, we can now use guide plates, so screw in studs are a viable option to the shims or z@#%&** adjustable pushrods!
NHRA 6390 STK
M/S 85 Mustang
Old 04-21-2009, 07:08 PM   #5
7423
Bob
I had a handful of rat motor valve springs shims left over from the Vega days. Just cut them up with tin snips, drilled a 5/16 hole and party on Garth!!
Charlie Allen
7423 is offline   Reply With Quote
Old 04-21-2009, 07:42 PM   #6
partsbob67
thanks guys. got some old feeler gauges i was thinking of using. just checking to see if there was some super-duper fix all 3 tenths faster shims i should use
bob beals 7244
Old 04-21-2009, 10:31 PM   #7
7423
"super-duper fix all 3 tenths faster" Get 32 of them Bob. I will split them with you!!
