Old 04-22-2009, 08:13 AM   #1
Stephen & Horace Johnson
Liked 163 Times in 53 Posts
Default Re: SS/E 2008 Mustang at Atlanta
Originally Posted by A/SA Fairlane View Post
I only tried to add 150 hp as that is the # you are throwing around. That is why I asked if you thought it should weigh what I posted. To answer your 150 hp question NO I don't think any combo is off by 150 and from this post neither do you? What 3 valve motor does Ford or anyone else make that is rated @ 510 hp? I hate to assume anything but I would venture a guess that your talking about the regular shelby that is factory 500 hp It has bigger valves (4 per clyinder BTW) more cam and more compression same cubes but you want the Cobra jet rated tha same?? While the CJ certainly shouldn't be 75 hp less it should be less. As for underrated combo debuts 94-98 LT 1 comes to mind 1st, then the 62 327 Corvette motor and I think I few mid 80 305 combos have had a ton of power tacked on over the years. Also the original Cobra jet as 428 has had plenty added to it over the years. I bet the new Cj's couldn't hang with Mr Pond Mr DeArmond o Mr Sorenson or Mr Barton or Mr Fiacci (sp) @ 450hp. Pure speculation on my part but time will tell I bet
Very Good Point
Stephen Johnson #2162
Horace Johnson #2167
Stephen & Horace Johnson is offline   Reply With Quote
