View Poll Results: Fuel injection? Do you run in open loop or closed loop
Open Loop 80 65.04%
Closed Loop 43 34.96%
Voters: 123. You may not vote on this poll
Old 04-28-2009, 05:47 PM   #1
art leong
Default Fuel injection? Open or Closed loop?
How do you guys run?
Art Leong 2095 SS
Old 04-29-2009, 05:58 AM   #2
Owen S Quirion
Default Re: Fuel injection? Open or Closed loop?
Open
BF/S 1985 Grand Am 3.0 V6
Owen S Quirion is offline   Reply With Quote
Old 04-29-2009, 12:07 PM   #3
larry dowty
Liked 11 Times in 4 Posts
closed
larry dowty 6388 SS
larry dowty is offline   Reply With Quote
Old 04-29-2009, 03:23 PM   #4
Ed Wright
Ed Wright's Avatar
Open.
Ed Wright 4156 SS/JA
Old 04-30-2009, 03:12 PM   #5
art leong
It seems pretty even.
I was under the impression that in closed loop if the O2 sensor gets a wacky reading it will throw the car way off.
How do you keep that from happening?
Art Leong 2095 SS
Old 05-01-2009, 10:36 AM   #6
Chad Rhodes
if you have a very close tune, you can just set the correction limits low, and correction factors small
Chad Rhodes 2113 I/SA
Old 05-01-2009, 12:30 PM   #7
larry dowty
art i moved the o2 sensor out of the collector up the header to 12 inches from the head made a huge difference in e.t.
larry dowty 6388 SS
Old 05-02-2009, 01:23 PM   #8
art leong
I can do that but it will just monitor one cylinder.
Art Leong 2095 SS
Old 05-02-2009, 05:38 PM   #9
larry dowty
yes it will only read one at a time
larry dowty 6388 SS
Old 05-09-2012, 10:33 PM   #10
Ed Wright
Ed Wright's Avatar
It will only read one period.
I have yet to see one run faster in closed loop. Have seen several faster in open loop.
If the car is slow enough you might make it work. I haven't seen one correct fast enough to work all that well with even a ten second car. Usually ends up not consistent. Tried it several times, won't waste my time with it again.
