Old 05-09-2009, 10:47 AM   #51
Lynn A McCarty
Lynn A McCarty's Avatar
Default Re: Ahfs
There are statistical clues on index corrections, too. GTAA is a good example. When several combinations are close to the bottom that is a major clue. This is the fault of the AHFS as it doesnt bear out the right numbers for corrections.
Lynn A McCarty 3470 SS
Lynn A McCarty is offline   Reply With Quote
Old 05-09-2009, 02:39 PM   #52
Don Kennedy
Liked 904 Times in 237 Posts
Default Re: Ahfs
Lynn:
Can you explain the whole correct system that you have told me about how the AHFS should work.
Don Kennedy 7701 SS
Old 05-09-2009, 08:25 PM   #53
Lynn A McCarty
Default Re: Ahfs
Engines can actually be rated by how exactly they perform against a racing standard. That is, we can actually rate them according to how they should have been factored to start. They should all perform the a prescribed NHRA Performance standard. If they out peform the standard they should get enough HP that warrants setting the engine back.
The biggest statistical error that the AHFS makes is all runs need to be corrected or it isnt apples to apples. Second is you dont compare a trigger of 1.15 under to an upper limit average like a second under, nor do you hit them with such a small number that it always stays on top. An engine going 1.6 under what does 15 HP do? That isnt even a tenth. How do you know if it deserves a tenth when he just ran in a mine shaft?
Bad statistics sometimes are better than none at all. If give you a feeling that something is actually being done when not much is happening. It could be a very useful tool if done correctly.
Old 05-09-2009, 09:57 PM   #54
junior barns
Liked 20 Times in 14 Posts
Talking Re: Ahfs
God only knows the cost of good heads .Have a nice day
Ed O'Brien 4191 STK
PRICELESS!!!!!!!
junior barns is offline   Reply With Quote
Old 05-11-2009, 12:06 PM   #55
Jack McCarthy
Liked 477 Times in 117 Posts
Default Re: Ahfs
lynn, your quote about bad statistics..yeah it sucks because it seems like something is getting done but without 100% pure stats it is just wasting our time and keeping a good system from being impemented.
unfortunately you and i know you will never get 100% pure stats if we know the triggers
jack mccarthy
why lower indexes -.50 ? why not ? why should 90% of the cars in the country be -.80 or better ??
been since 1980's since they RAISED them, and anyone who cant run the index should take a local auto mechanics class.
Jack McCarthy 3609 STK
"the Captain"
Jack McCarthy is offline   Reply With Quote
Old 05-11-2009, 03:49 PM   #56
Ed Wright
Ed Wright's Avatar
Default Re: Ahfs
Ed, I don't understand why you can't just say what you think.
Ed Wright 4156 SS/JA
