I just had 4 wheel alignment done they found rear end 1/8 out of square adjustable 4 link chevelle. Also replaced VW tires with moroso ds2 28 inch car has slight tow in sitting yet none at 4 inch. With 15 lbs in 28/10.5 mt. weighing 3600 lbs I can pull car forward with one hand by the door handle. Night to day difference. My disc brakes turned the sliders in drill press polishing with sand paper release good. Good luck
i |
On the topic of disc brakes, on gocarts (JrDragsters) we had disc brake calipers that you could adjust with a set screw to back them away from the disc. Maybe someone needs to "invent" something like that to reduce drag.
