Old 05-27-2009, 10:06 AM   #1
67ss
Default Re: Fuel Filter Recommendations
I just went through this. Replaced my blue holley pump with a black holley. Had a Mallory filter with paper element before pump but was told by holley that you should never use a paper element before the pump even though Mallory and BG use paper before their pumps. Who knows. Holley recommends a screen type filter before the pump to make sure you don't get any cavitating of fule at the pump. At any rate I really didn't have room for the paper element filter without running the line up hill which I was trying to fix. I ended up getting an Earl's in line filter with a stainless steel mesh screen (85 microns). Was able to easily plumb it inline with my -8 line before the pump. I screen my fuel when I put it in the cell as well, so I didn't really see any point of running any other tighter mesh filter after the pump.
Chad Harris
67 Chevelle SS
http://mysite.verizon.net/harrisracing
67ss is offline   Reply With Quote
Old 05-27-2009, 10:40 AM   #2
sst1226
sst1226's Avatar
Liked 11 Times in 2 Posts
The info I could find on my filter is that the element is a 10 micron filter which If I'm not mistaken means that it can filter very fine particles so it should probably go after the pump. My initial concern is that the fuel pump would just push any particles right through the filter if I mounted it after the pump, but I assume that a 10 micron filter wouldn't allow that.
I too use a funnel with a tight metal mesh screen when I fill the fuel cell up to catch anything particles from the gas can.
According to Holley's website, they reccomend the use of a coarse screen type filter before the pump, which I'm assuming is one rated with a higher micron number and a high-quality pump after the filter which I'm assuming would be rated at a lower micron number to filter out fine particles like a 10 micron?
Mario DiTeodoro III SST/SG1226 STK126M
sst1226 is offline   Reply With Quote
Old 05-27-2009, 10:52 AM   #3
67ss
Correct. You want a course screen type before the pump (I think they recommend 100 microns) then the tighter filter after the pump if anything at all.
That Earl's is part number 230208 . $46 from Summit.
Chad Harris
67 Chevelle SS
Old 05-27-2009, 11:08 AM   #4
sst1226
sst1226's Avatar
Thanks for the help!
Old 05-28-2009, 09:34 AM   #5
Jack McCarthy
Liked 477 Times in 117 Posts
aeromotive says thier pump would rather pump some dirt than run partially dry, so they insist the filter be on the motor side of the pump... i also run another one 3 inches from carb
jack
Jack McCarthy 3609 STK
"the Captain"
Jack McCarthy is offline   Reply With Quote
