Old 06-10-2009, 10:40 PM   #1
rick lester
Liked 4 Times in 1 Post
Default Re: electric fans relay question.
circuit breakers are rated at 30 amps, just like the relays. been two days and all is fine. one bad thing is stock 1988 chevy suburban temp. gauge is off by 20 to 25 degrees. fans come on at 185, gauge reads between 205 and 210. i'm assuming since its a 185 on, 175 off thermostatic sensor since thats what i ordered. one thing i did do different than the directions said, i hooked the yellow wires to a live slot in fuse box instead of to ignition. this way the fans stay on until its cooled down to 175, even if the suburban is shut down. rick.
rick lester is offline   Reply With Quote
