View Poll Results: .031" Dykes or .043" Rings ?
.031" Dykes 41 33.88%
.043" .155" radial moly ring with lateral gas ports 39 32.23%
.043" .134" radial moly ring with lateral gas ports 31 25.62%
Other, Make suggestion 10 8.26%
Voters: 121. You may not vote on this poll
Old 06-15-2009, 12:54 PM   #1
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
Default Re: .031" Dykes or .043" Rings ?
My LT-1 had 1/16" top ring grooves and I used std. top rings with cutback seconds and very low tension oils......I have used the .031" dykes with spacers in a 5/64" groove if I remember right in my 350/255 back in the '90's......Do the .043" rings go in a 1/16" groove with spacers.....and the rings are where the gas port grooves are cut ? .......the spacer would be pretty thin and I have no experience or knowledge of the gas ported ring setup. Just curious about this and I might need the knowledge for a future Stocker engine project for someone else........
Rich Biebel
S/C 1479
Stock 147R
Old 06-15-2009, 01:19 PM   #2
Woodro Josey
Liked 3 Times in 1 Post
Well Patterson and Bub, i too agree with you guys,,,,Total Seal now can supply you with Gas Ported spacers to go with the .043 Top Ring. I haven't seen this metioned but, it is illegal to machine Lateral Gas Ports in a Stocker piston,,,sooooooo!!!!!!!!!!!! The .043 Diamond Cut ring or 1/16 or 5/64 Diamond cut is the way to go but, a little pricey!
Woodro Josey 2002 STK
Woodro Josey is offline   Reply With Quote
Old 06-16-2009, 07:47 PM   #3
Ed Wright
Ed Wright's Avatar
I'm suprised at the poll resuslts. Didnt know anybody still used dykes rings.
Ed Wright 4156 SS/JA
Old 06-16-2009, 09:29 PM   #4
larrylomascolo
Liked 66 Times in 29 Posts
I used the .031 dykes ring ordered , tight and lapped all 8 for a s/s motor,worked great ,alot of time and sore fingers ,does anybody still do this today,
Old 06-17-2009, 06:37 AM   #5
Tilley2007
Guest
Posts: n/a
What about the .7 & .8 mm rings & 2 mm oil rings for engines in the 8,000-10,000 rpm range?
Old 06-17-2009, 07:44 AM   #6
RJ Sledge
Liked 288 Times in 90 Posts
Just to let everyone know that PMS in San Antonio, Texas, owned and operated by non other than Adrian ( Pudgy) Pendergrass makes a very nice set up to Gas Port the Spacers. If you have access to a mill its a piece of cake to do it yourself and save some money. 210-681-2405
RJ Sledge is offline   Reply With Quote
Old 12-04-2010, 07:46 PM   #7
Daran Summerton
Daran Summerton's Avatar
Liked 66 Times in 37 Posts
I vote for vacuum pump and no second rings
72 cutlass
Daran Summerton is offline   Reply With Quote
