Liked 165 Times in 59 Posts
there seams to be no recomended presures for the radial slicks,i have a new set of hoosiers 9x30r car weighs 3665 with the driver ,,,,i run 16 psi in the bias ply 29.5 x 9 with good results just looking for some comparison with simular weight cars gmonde
Liked 251 Times in 51 Posts
18 pounds at 3400.
#5457 Curt Rees
Curt Rees 5457 SS |
Liked 138 Times in 51 Posts
Lots of variables, including car weight, weight transfer, suspension hit, rim width, etc.
I have the Hoosier 9" lightweight radials on 10" rims, car weighs 3,540lbs + and I footbrake. I've been running 21 lbs. of air. It's been a while since I ran the car over 3,700 lbs, but I don't recall changing the pressure then.
LOCOMOTION Racing Last edited by Myron Piatek; 06-18-2009 at 08:17 PM. |
Our Deal, 22 PSI
Ron Zenzen 5402 SS |
Liked 39 Times in 5 Posts
I run a 3600 pound wagon with a 305 and can run up to 35 pounds without any issue.
Norm Webber LSA 6635
Norm Webber |
Start at 20lbs and go up from there. Talk with some of the guys running coil spring cars, they can tell you what will work.
See you at LV George |
I have been running 22lbs. with 30X9 Hoosier light weight radials in a 3500lb. Stocker with CalTrac leaf suspension. Jim
Jim Wahl....NHRA #2239 S/SS - IHRA # 8 Stock, D2 Stock Champion (forever I guess) 2019 Baby Gators Stock Champion 2009 NHRA D2 National Open Stock Champion 1982 NHRA D2 West Palm Beach LDRS SS Runner Up Past President, Southern Stock / Super Stock Association. ![]() |
Liked 6 Times in 3 Posts
3560# chevelle, 25.5 pounds on an 8 inch rim
Ian |
Liked 6 Times in 4 Posts
I agree. 30X9 Hoosier (CO7) radials 19-22 lb 3500 lb foot brake. Depends on track
Liked 759 Times in 379 Posts
Been running Hoosier's 30 x 10.5 radial slick on my nose heavy 3880 lb. BB Chevelle since the 2000 season using 3 pairs a season, pulling them off at 75 passes and typically aired to 18 psi.
Have gone 100+ passes on a set and I've run them with as much as 20 psi. Have gone a best of 1.28 60 foot and 1.36 60 foot breaking the beam with the back tires. ![]() ![]() My rule of thumb is to start at 5 psi more than what you ran with bias slicks. Last edited by 1320racer; 06-19-2009 at 08:57 AM. |
