Old 06-18-2009, 10:08 PM   #1
GarysZ24
GarysZ24's Avatar
Liked 256 Times in 103 Posts
Default Re: Jeg's All Star coverage!
Originally Posted by Bobby DiDomenico View Post
That would be OK since they are staging with the same device correct? In the example above they are sayng a car which stages with the tire broke the win beam with body work. Not good.
Is that why they moved the spectator stands away from the finish line at Joliet? So you can't see who actually won? :-)
Bobby, I was the one who made that comment, and last night I re-watched the staging of both cars, and it looked to me as though the Cavaliers front end moved forward of the staging beams to thus stage with the tire, however the freeze frame at the end showed the Cavaliers tire clearly being behind the rear-most edge of the wagons front tire as it tripped the finish line beams. However, the front nose of the Cavalier was right there close enough to the front edge of the wagons tire to explane the narrow victory for Greg...I hope somebody else who saw/taped this race will look at it so as to agree/disagree with my oppinion, but as I said before verrry interesting....
Gary Hampton
'86 Z24,173 V6
CF/S #5824 (#78 in 2021)
Old 06-19-2009, 09:53 AM   #2
partsbob67
Liked 79 Times in 11 Posts
some of the guys that i bracket race with use a "stripe taker" mounted up by the front bumper and it only hits the beam at the top end. they stage with the tire and take the stripe with the wing. cheatin bastards!
bob beals 7244
partsbob67 is offline   Reply With Quote
Old 06-20-2009, 07:07 AM   #3
Bryan Worner
Liked 535 Times in 86 Posts
The coverage was good, except for one thing I noticed that was not mentioned on here! The top end cameras were at the 1000' mark!!! Showing once again how everything is geared towards the pros! Only the finish line cameras (still) were shown at the stripe, everything else on top end was from the 1000' to the down track cameras! It was not like that last year.
Bryan Worner is offline   Reply With Quote
Old 06-20-2009, 05:48 PM   #4
GarysZ24
GarysZ24's Avatar
Angry Re: Jeg's All Star coverage!
You're right Bryan, and I didn't like that either...ESPN IF YOU'RE READING THIS THREAD, I HOPE YOU'LL FIX THAT ISSUE, SO WE GET FULL TRACK COVERAGE IN THE FUTURE TOO...AFTER ALL, WE SPORTSMAN RACERS ARE THE PRIMARY BILL PAYERS OF THE NHRA!!!!
Gary Hampton
'86 Z24,173 V6
