Old 06-27-2009, 12:26 PM   #1
Default Re: Ball Joint's of choice?
Originally Posted by blasttime View Post
Why would you not use the correct required length for your applacation? This is not a well thought out modifcation in my opinion.
Actually, it is a very well thought out modification. Without the longer ball joints, you have serious alignment and bump steer issues, and you are over stressing the ball joints by using them for stops, and doing it at a severe angle. The car will work much better with the longer ball joints.
Old 06-27-2009, 02:11 PM   #2
blasttime
blasttime's Avatar
Wink Re: Ball Joint's of choice?
Measure your shock compressed and extended buy the right length ball joint. Why would you install .5 long stud to ruin a shock .1,.2,.3,.4,.5 length studs can be had.
blasttime is offline   Reply With Quote
