Old 07-07-2009, 10:13 AM   #3
Dick Butler
Liked 32 Times in 19 Posts
Default Re: Help with ladder bar adjustments
68, The above suggestion is "not quite correct" On a ladder bar its length at which it trys to Pick up is set by its length, not its height at the front. If you raise the front it hits harder or more pressure. If you lower it the lift is less. If raising it hurts 60 ft try adding more tire pressure then to support the tire footprint. Have someone watch only the slick or rear tire to see if it smashes flat as indicator it needs more air.
Dick Butler
