Old 07-07-2009, 08:57 PM   #4
Z28-69
Default Re: 1969 Camaro BBC TH350 Crossmember
I'm not sure on this but don't the big block mounting brackets push the motor forward about an inch which would give you that what you need. I'm not talking about the motor brackets but the ones that mount to the frame. I know on my buddies car his are different than mine and his car came factory with big block, and mine obviously came with small block. Probably easier to drill new holes but that might be why your not fitting.
Z28-69 is offline   Reply With Quote
