#11 |
Liked 336 Times in 183 Posts
Dwight-- Yes how viable is that combo??? FED387
#12 |
Liked 784 Times in 196 Posts
It wouldn't be one of my choices. It has small valves (1.72 & 1.5), pushrods and blueprinted compression is only around 8.5 to 1. Out of all the 151 combinations, it seems to have the best specs. Is it a multi-port injection? I'm not all that familiar with those engines, but a power to displacement ratio of close to .8 (120/151) requires that it be a stellar performer. That alone would make it hard to perform against other possibilities in those classes.
#13 |
OK using the same 82 Camaro what other competitive classes are there maybe a v-6???
#14 | |
Liked 8 Times in 7 Posts
so, i'm MY case the car itself can be 50#s light? l weigh in at 230, uh, ish..... |
#15 | |
The 151 in the Camaro is TBI......... Hp is too high . Wouldn't you rather have a 196 (3.0) Buick V 6 at 115 hp in a Monza?
#16 |
Liked 7,925 Times in 1,760 Posts
I sure would!
#17 |
#18 |
Dwight/Alan----I understand now and then you go to the technical area to find out what head/intake/carb etc is allowed correct??? Thanx fed387
#19 |
That is in the Engine Blueprint Guide. Cam lift and valve sizes are there as well. There is also a piston guide and a connecting rod guide.
Alan Roehrich 212A G/S |
#20 |
Dwight/Alan--- OK I understand the whole thing now--Now I have a clean 1982 Camaro Factory 4 cylinder /auto trans car----PLAIN JANE kinda car no air/windows etc... Decent shape in/out gotta be light I'm sure--I understand you can change these around to different years by changing front fascia/grill and taillights---with a V-6 OR 305 4bbl carb motor what class do I want to run with what factored engine and what year---not looking to set the record but dont want to look like a complete a--hole out there either---want to run a bit under the index first time out-then will work on the combo to be quicker-thanx fed387
