Old 07-20-2009, 03:08 PM   #1
Ross Family Racing
Liked 51 Times in 14 Posts
Default Hoosier Radial Questions
Do those of you that run Hoosier Radial 9x30 rotate them every so often? How often? How many passes do you get out of them on average? Thanks,
Jeff Ross
Ross Family Racing is offline   Reply With Quote
Old 07-20-2009, 03:27 PM   #2
Mike Fuller
Liked 198 Times in 79 Posts
Default Re: Hoosier Radial Questions
I rotate mine aout every 4-5 runs. They usually last about 90-100 passes,if you don't get crazy in the water and try to look like John Force.
Mike Fuller 396 STK
3961 SS
Mike Fuller is online now   Reply With Quote
Old 07-21-2009, 05:20 AM   #3
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
Originally Posted by mike fuller View Post
i rotate mine aout every 4-5 runs. They usually last about 90-100 passes,if you don't get crazy in the water and try to look like john force.
x2
Old 07-21-2009, 02:43 PM   #4
j gardiner
Liked 55 Times in 29 Posts
I was talking to a hoosier tire rep the other day about which way the tires should be mounted, he said it did not matter. he also said you should only rotate them if the tread starts to feather up, and after a run or two you should put them back. do not switch them back and forth. they will last longer this way.
j gardiner is offline   Reply With Quote
Old 07-22-2009, 07:23 AM   #5
Dave Ribeiro
Liked 56 Times in 27 Posts
Wink Re: Hoosier Radial Questions
j gardiner,
I agree and have been doing it that way for 10-15 years...They do last longer, and you don't need to have a Smoke-Show anymore, just a little smoke is fine....LOL,
* They still outlast the rest in Radials.........
Dave Ribeiro 1033 STK
Old 07-22-2009, 07:59 AM   #6
SC2422
SC2422's Avatar
Same here.....I've blazed "em to the starting line and done a burnout with what you can barely call smoke. 60's arent any different.
65 runs, same side. The best part...I push it in the trailer at 20lbs, I back it out a month later. 20lbs in each tire! (even with a new found plug in one tire)
SC2422 is offline   Reply With Quote
Old 07-22-2009, 08:13 AM   #7
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Jeff Ross
Never in 8 seasons/24 sets using Hoosier's 30 x 10.5 radial putting 75 passes on each set running as quick as 9.89 and a best of 1.28 60 foot and the 60 foots are deadly, typically varing thousanths in 60 foot from pass to pass.
Afterwhich they go on a less power/lighter mid 10 second car for another 75+ passes.
The most I ever put on a set was 115 passes at the end of the season on good starting lines.
