Old 07-29-2009, 12:01 PM   #11
Jack McCarthy
Liked 477 Times in 117 Posts
Default Re: Dry Ice At Indy
my fuel checked @ 54 degrees at bowling green for record run on hottest day of year so far in kentucky... with no artificial help ... just chilled fuel for several hours prior to heading to staging lanes, have well thought out cool can and insulation for lines...
has been checked as low as 48 degrees ... just use you head and manpower, save money and risks
and the temp guage was still on 100 at scales
jack mccarthy
Jack McCarthy 3609 STK
"the Captain"
Jack McCarthy is offline   Reply With Quote
Old 07-29-2009, 12:35 PM   #12
Stephen & Horace Johnson
Liked 163 Times in 53 Posts
jack mccarthy
Can you get the fuel to cold, and it creates condensation in the carbs?
Stephen & Horace Johnson is offline   Reply With Quote
Old 07-29-2009, 06:59 PM   #13
Jack McCarthy
it doesnt help as much when outside temp is under 70 degrees
never had it slow me down !
jack
"the Captain"
Old 07-29-2009, 07:37 PM   #14
dartman
dartman's Avatar
Liked 68 Times in 41 Posts
Originally Posted by james schaechter View Post
Ed, please explain. Is it the fact that it could burn the skin or what is it? There are a lof ot things in the lanes or the pits that could hurt a kid or an animal that we use at the track.(if not handled properly) Not trying to be a smart a@@, just wondering.
If you hold a piece of dry ice too long, it feels like it is burning your skin. Your skin isn’t actually burning, though. What is actually happening is that the dry ice is freezing your skin. The dry ice is carbon dioxide that has been frozen at -110 °F (-79 °C). That’s why it hurts when you hold it too long, because your skin is starting to freeze from its cold. Freezing skin is a bad thing, so I recommend not letting dry ice ’burn’ you.
The reason that freezing and burning can feel the same is because touching things that are very cold can do the same thing to your cells as touching things that are very hot. The burning feeling comes from some of your skin cells being damaged and breaking open. This happens when the cells’ membranes are broken open. (You can think of the cell membrane as the wall of the cell.) If you touch something hot, some of the cell membranes are actually melted, breaking the cells open. If you touch something very cold, the water in your cells turns into ice, forming crystals that can tear through the cell membranes. In either case the result is the same - the cells are damaged. This is what you feel.
1231 FS/D Drag Pak
1231 E/SA 71 Demon
Kelly MacKay
dartman is offline   Reply With Quote
Old 07-30-2009, 05:40 AM   #15
George Fitzpatrick
George Fitzpatrick's Avatar
Liked 94 Times in 24 Posts
Wow that was a great explanation. Thank you
George Fitzpatrick 426 HEMI STK, SS
George Fitzpatrick is offline   Reply With Quote
Old 07-30-2009, 08:43 AM   #16
Schenck
FYI
found this on NHRA's website under rule amendments for Alcohol dragster and funny cars.
“Artificial cooling and/or heating of fuel (i.e. cool cans, ice, Freon, etc.) prohibited on the car. Insulated fuel lines and fuel tanks prohibited. Artificial cooling and/or heating of fuel confined to the pit area only. The use of dry ice and/or liquid nitrogen for artificial cooling of fuel prohibited.”
Greg Schenck
Schenck is offline   Reply With Quote
Old 07-30-2009, 11:22 AM   #17
Bill Grubbs
Liked 564 Times in 66 Posts
Break right, break right, chaff, chaff, chaff!!!
Bill Grubbs is offline   Reply With Quote
Old 07-30-2009, 11:24 AM   #18
Ed Wright
Ed Wright's Avatar
[QUOTE=Schenck;132502]FYI
"Artificial cooling and/or heating of fuel (i.e. cool cans, ice, Freon, etc.) prohibited on the car. Insulated fuel lines and fuel tanks prohibited. Artificial cooling and/or heating of fuel confined to the pit area only. The use of dry ice and/or liquid nitrogen for artificial cooling of fuel prohibited."
Doesn't mention that under Super Stock.
Ed Wright 4156 SS/JA
Old 07-30-2009, 12:29 PM   #19
treessavoy
Liked 4 Times in 4 Posts
It's like anything else, judicial and intelligent handling make the product safe but there will always be someone that will act just plain stupid.
Should you ban NOx at the event just because some idiot might try and sniff a bottle?
Somewhere there has to be a balance and people have to take responsibility for themselves.
Jim R
Jim Rountree
Old 07-30-2009, 03:45 PM   #20
Schenck
[quote=Ed Wright;132546]
Originally Posted by Schenck View Post
FYI
Only a matter of time.
My guess something they were doing was getting out of hand.
Greg
