Lokar makes a kit to locate a Master Cutoff Switch shutoff lever inside the car:
http://www.lokar.com/product-descrip...ttery-disc.htm |
Liked 10 Times in 7 Posts
in my case.......dragster.....(i know...wrong side.. .90 / s ss lol) I'm right handed with button on right side of s/wheel, my rod for the master switch is also on the right.....so I would be in a jam, sorta. I hope I would have the present of mind to kill the car with the ing.switch which is on the left side of dash (without removing rt. finger off t/b button.
At the old St. Louis track, I had my accellerator stick wide open@ the big end. First pass on car after my two year retirement. Yeap ! scared the **** out of me, hit the brakes......no good, finally reached up and killed the ing. switch. that worked...................got hung up on the hood. Now , i always use stands to check the drop. And after blowing up a convertor, on the stands, checking the stall..........I don't do that anymore either. My stuff dosen't go WOT unless I'm at the starting line.
Rick Bailey 3439 SC |
When I went to Frank Hawley's Drag Racing School the KILL switch was RED & LIT in the middle of the steering wheel.........I LIKED THAT !!
Liked 4 Times in 2 Posts
It appears to be a standard in S/G and S/C as we are too mindless to turn it on....after we are buckled in...after we had our SS car built we added it....an accident is a lot more likely in the super classes because you're always checking your stop speed.....But the rear wheels need to be off the ground...period...
Rock |
Liked 18 Times in 8 Posts
Henry, check your PM....Wade
Liked 276 Times in 27 Posts
Sit in your racecar and strap yourself in. If you use your right hand to activate the transbrake button, try reaching the ignition switch with your left hand to see if you could shut off the engine in an emergency.
Racers are highly intelligent when it comes to making a racecar go fast. Use some of your intelligence to make it safer. Travis |
Liked 11 Times in 8 Posts
Hell I just assumed you meant on the starting line, in that case I wouldn't know any different till the finish line. As for stall testing I'm not a big fan, won't do it unless I'm at least on the track, don't have the stones to hold the chain saw wide open otherwise. I have over the years witnessed this at different tracks and I vacate the area as soon as the guy stomps it, never know if he may have brain fade and just let go of the button. Joe
Joe Buchanan SS/BX 3117 |
Liked 557 Times in 217 Posts
I have a RaceTech dragster and it has a master battery shutoff within easy reach of my left hand. Push type rod/cable just below the dash. I have occasionaly sat in my car and thought what would I do in an emergency if my throttle stuck. I practiced the various hand motions I might need. I also have two brake systems completely seperate, one foot one hand lever. My last dragster was Ron's injected. Fuel shutoff cable was within easy reach of my left hand. That would have been my first move in a stuck throttle situation, shut off the fuel, pull the chute, kill the switches......My present car it would be pull the chute, battery off, switches off.
My good friend had his throttle stick at the finishline at Island Dragway. It was an 8.90 something run at 153 mph in a '67 Nova. He reached for the shifter to neutral it and somehow engaged reverse in spite of the reverse lockout feature of the shifter........that car was destroyed when it locked the back tires spun around and rolled over. His safety gear did a goodjob and he was basically unhurt.....
Rich Biebel S/C 1479 Stock 147R Last edited by Rich Biebel; 08-10-2009 at 01:45 PM. |
