Liked 11 Times in 8 Posts
Yes Adger the shift RPM is quite high,I'm trying running 3 intermediate clutches this time with a different friction material. 2 frictions just didn't seem to cut it in my application. As for the shift timing it appears to be OK, as I see nothing on my Dataloggers accelerometer to indicate a conflict of the clutches. Joe
Joe Buchanan SS/BX 3117 |
Liked 308 Times in 103 Posts
On 1-2 shift intermediate drum has to swap directions,thats why supposed to start burnout in 2nd
and not shift from high to neutral (rev. pattern) at any speed besides stopped.that is what destroys intermediate sprags on th 350 rev. pattern. Mike Taylor3601 |
#3 | |
Banned
That's what Coan told me said you couldn't shift from high to neutral without trans not trying to swap
directions on intermediate drum not mention how many cars have been crashed by getting put in rev by accident most had rev lockout but got past somehow.Coan has clean neutral on some trans I've seen where has a second neutral past high gear {rev. pattern} Mike Taylor 3601 |
has anyone ever compared the A1 pro-flites (or whoever makes them now) with the coan XLT 350?
Liked 224 Times in 87 Posts
I thought the top stock Coan 350 xlt with double " N " shift pattern was designed / built so you could shift into " N " in the shut down and click off the motor ? Looks like a nice piece but I don't no anyone who runs one or how many runs you can get out of one ? Did call Coan and what did they say ? .....
My trans has the "clean" nuetral, that's not an issue just can't keep intermediate clutches in it.I'm hoping that the latest "fix" is the cure. Now I've been told that adding the third disc is going to slow me down, I'm not really grasping the idea however I've been told this by a few trans guys. Since I still have clearence in my clutch pack I'm unable to understand how this is going to slow me down. Can someone explain? Joe
That's right clean neutral is to shut down in neutral without trans damage or risk of accidently shift
in reverse. Joe, sounds like one of those problems ''nobody else'' has had I've been there before I don't know you but from reading you're post/replies for awhile I say you have the abilities to figure it out. You may air test piston in drum thats giving trouble see if releases as quick as others or you can stack assm.of drums like trans was together,except outside of case and apply air through pump passages and check how things are working.I found problem in 350TH that way once.I also used mitchell manual told when this was applied for this gear that was applied for that gear etc.could help track down problem. Mike Taylor 3601 Last edited by Mike Taylor 3601; 08-31-2009 at 11:58 AM. |
