Liked 16 Times in 11 Posts
If you remove the sealant where the two halfs come together and reseal them and ad a sealer spray around the inside they will work very well tubeless. Yes take the wheel apart to reseal.
Bob Pagano A/SA |
I still use a set of polished Super Tricks on the rear of my SS/EM car. They are 15 x 14. We use silicone to seal them up and have been running them tubeless for years. They are very lite and compare weight wise to Weld Aluma Stars That I also have a pair of.
Liked 308 Times in 103 Posts
If you put 13'' wide tires on 14'' wheel tire will not grow as much and slightly raise finish line RPM
13'' wide tires on 12'' wheels they will grow more and slightly lower RPM at finish line. Mike Taylor 3601 |
