I ran the same setup on a 265" in the '60s and early '70s. Some guys made a wire hook to hold them wide open. I tried that, but good ol' Red Anderson made me take mine off. The car ran the same both ways. If you think that is the problem, tie the weights up to see if it actually is. I saw guys drill holes in the thick (heavy) weights to lighten them, they came with two different weights. Mine all had the thin weights. I would be suprised if that is your problem.
Good luck, Ed
Ed Wright 4156 SS/JA |
I'll try the wire open suggestion. The real trick is getting the rear booster venturies flowing fuel without leaning out and stumbling more than before with the weights swinging loosly based on the air flow signal. The throttle linkage is set to open both carbs together. What are the other possible explainations for this mid range stumbling? Thanks for the help.
Liked 16 Times in 11 Posts
To much fuel presure
Bob Pagano A/SA |
Liked 520 Times in 132 Posts
Mike Braswell runs this setup on his 57' Chevy Super Stocker. He reads this forum he may chim in.
Liked 20 Times in 15 Posts
Do you run wedge plates between the carbs & the spacer/manifold? Because of the small bowls in the WCFB they may run out of gas for a split second then perk up when it gets fuel again. The angle plate helps with this.
