When a class car passes a teardown I've heard they "seal" it. I assume this is so they don't need to take anything apart again unless it becomes unsealed.
My question is what do they do or use to seal it? If I have any of this incorrect please forgive me, I'm just trying to understand this process. Thanks in advance for any answers. |
Liked 5 Times in 3 Posts
They (IHRA) sealed my engine everytime I set record...BUT if it was still sealed & it was a new season it still had to come apart
How is it sealed is what I'm trying to find out.
Liked 100 Times in 45 Posts
You might not get an answer to that.Some people don't want to give a top secret weapon away.See the post about the quickest D/SA in the country.
Former NHRA #1945 Former IHRA #1945 T/SA |
All I'm asking is what they are looking at to see that it is still sealed.
Not looking for any secrets on anything. We race in a diiferent form of motorsports and are asked quite often to pull the intake and a head. We do that, everything passes tech, we are good to go only to get asked again a month later. Even when they watched us put it back together. They say well we can't tell if you took it back apart or not. So I'm just trying to find a visual thing that they can put on the block and head or intake that would have to be removed or cut off or whatever if a person was to remove a head or intake manifold. So all I'm looking for in this post is what does NHRA or IHRA use to see visually that you have not taken it back apart. Thanks. |
Liked 275 Times in 76 Posts
In past years on friends that had gone through teardown, an orange or red colored plastic was dabbed over an intake bolt. If the bolt was removed, the plastic would have been in the way of a socket and would show.
I think this is the info you are asking about? Sean
Liked 11 Times in 8 Posts
There are several ways I've seen engines sealed. First is the colored paste used by I&N they put it on various fasteners that would have to be removed to make any changes, carb studs,intakebolts, ect. The second I've seen in carting they use drilled studs and insert wire with a crimped tag that would keep it from being disassembled without tearing up the tag. You could ask your tech. guys to devise a way of sealing your engine, maybe they will work with you on this, the cost of gaskets are not going down not to mention the labor involved. Joe
Joe Buchanan SS/BX 3117 |
#8 | |
We have had our carburetors "tech painted" last year at the Memphis D4 race. not for a record or anything. They just told everyone to pull their carb, bring it to the trailer and submit it for inspection
Chad Rhodes 2113 I/SA |
#9 | |
Ed Wright 4156 SS/JA |
#10 | |
BTW this was done on Fri afternoon with teardown on Sat morning so I did have the car in my pit area till then.Some of the stuff is still on the intake,water pump and head bolt to this day.
