Old 09-14-2009, 12:37 PM   #3
Eric Merryfield
Eric Merryfield's Avatar
Liked 502 Times in 130 Posts
Default Re: Epping Redlights and rollout change?
Originally Posted by Michael Beard View Post
No.
The distance between the pre-stage and stage beam is irrelevant to your rollout if you are shallow-staged. You could take the pre-stage beam and throw it away. For shallow stagers, rollout is determined by the HEIGHT of the STAGE beam. Changing the distance between the pre-stage and stage beams would effect the rollout for a car that is Deep-staged.
Thanks, so I get this straight, if the height of the stage beam is a bit lower? it will decrease reaction times and vice versa if a bit higher? Hadn't really thought about this before sort of explains track to track uniqueness, with shallow staging all other things being the same. How level the beam is would be important too.
Eric Merryfield 1883 STK
