Old 09-25-2009, 08:21 AM   #1
Alex Denysenko
Alex Denysenko's Avatar
Liked 4 Times in 3 Posts
Default Re: IHRA coming to my local track PBIR, Can I run in any of the classes?
Replacement rear upper and lower control arms are allowed in stock.
Only the uppers can be adjustable, the lowers cannot.
I do not think that IHRA would have a problem with the grill or louvers.
Even NHRA allows non Z-28 Camaros to use Z-28 trim.
Aluminum drive shaft is allowed in IHRA stock.
Pullies should be OK.
Cold air kit needs to be looked at by IHRA tech as some direct replacement units are OK.
Good luck.
Alex Denysenko NHRA 3038 SS, 3305 STK - IHRA 6 SS, 330A STK
Moneymaker Racing LaPorte Indiana 219-861-1214
www.moneymakerracing.net
Alex Denysenko is offline   Reply With Quote
Old 09-25-2009, 08:23 AM   #2
Tweaker
Tweaker's Avatar
Good luck.
thats good news. My control arms are both non-adjustable.
Do you think I fit more in with Stock Fuel injected or Modified stock, im trying to see who i can contact at IHRA for more info. What division is FL in IHRA?
Tweaker is offline   Reply With Quote
Old 09-25-2009, 08:34 AM   #3
Tweaker
Tweaker's Avatar
so they add 170 pounds to the car's weight no matter what?
I only weigh 160.
Old 09-25-2009, 08:54 AM   #4
Bob Don
Bob Don's Avatar
Liked 905 Times in 193 Posts
Tweaker - You need a crash course in class racing. Classes are determined by horsepower to weight ratios. Each engine has a horsepower rating assigned by NHRA or IHRA. Each car would get a hp/weight factor depending on the listed shipping weight of each vehicle. This is what determines your class. (170 lbs driver weight is added to shipping weight to determine minimum racing weight. It doesn't matter how much you weigh.) You are then allowed to do certain modifications depending on your category. Stock can do so much, Super Stock even more. You then must be able to run on or below the ET index for your class. The problem is that you would probably not be able to run your index without building your car to the limit of the rules. (acceptable cam and valvetrain, blueprinting, gear ratio etc.). If they run a bracket program with the IHRA race, you'd be far better off there.
Old 09-25-2009, 09:02 AM   #5
Tweaker
Tweaker's Avatar
Dang, Sounds complicating. = { I thought in the stock class you could not change your cam and other things. = \
Old 09-25-2009, 09:56 AM   #6
Jack McCarthy
Liked 511 Times in 122 Posts
ill bet he'll tech in superstock ok...
jack
Jack McCarthy 3609 STK
"the Captain"
Jack McCarthy is offline   Reply With Quote
Old 09-25-2009, 11:01 AM   #7
Tweaker
Tweaker's Avatar
jack
im assuming id get killed in super stock, can't you use electronics in that class? i dont have any :P
Old 09-25-2009, 10:00 AM   #8
Dion Hildebrandt
Dion Hildebrandt's Avatar
Dont be discouraged i went through all of this a couple of years ago, once you take your bumps and bruises it is an absolute riot. Get a rule book and find some class racers and ask a LOT of questions
Dion Hildebrandt 6009 STK H/SA
Dion Hildebrandt is offline   Reply With Quote
