i'd say ice and less oil is worth probably .15-.20 for us on a hot day not so much in this cold weather. ie 50-60 degrees. maybe a tenth at best. I guess it all matters on how much oil you run on the regular, lol.
Dusty Lowell #1773 STK F/SA |
Liked 11 Times in 8 Posts
Unless you're running a stock type oil pan I see no reason to believe there would be an E.T. gain by draining oil from the engine.Basically the only thing you're doing is reducing windage in the crankcase. With a properly designed pan, scraper and if possible windage tray draining oil is only going to hasten the death of your engine. I would opt for some of the ultra low viscosity oils instead, at least you would have a steady supply of lube to the bearings, although it does have the consistency of water, some lube is better than no lube. As far as running the engine "cold" I do that. After fully warming the engine I leave the water pump and fan on till the water temp is ambient, seems to be a little faster, of course you need a pretty effecient cooling system to accomplish this in later rounds. Joe
Joe Buchanan SS/BX 3117 |
Liked 6 Times in 5 Posts
Dusty: .15-.20??? Really??? With how much less oil??? This thread scares the crap out of me!
Carefull Dusty...
Bub Whitaker |
Liked 419 Times in 96 Posts
Liked 23 Times in 13 Posts
KIDZ, what do they know anyway!!! Still WET 6qts, back down da timing, and turn up da HEAT, works for me!!!
Frank Bialas 1570 STK |
