Old 10-14-2009, 01:14 PM   #1
Ed Wright
Ed Wright's Avatar
Default Re: ET difference w/ less oil
Originally Posted by mark callanan View Post
You run a run with less then 100 water temp?
I do, once the oil is warm. Zero weight oil and coolant down to 70 degrees (digital gauge) or so is what mine likes. I fill the filter and put four qts in the pan. Never had the nerve to run it lower than that. Ends up about 100 to 110 at the starting line. 112 to 115 or so at the finish line. Been running the same bearings for two years now.
Ed Wright 4156 SS/JA
